10-29-2019, 11:03 AM | #1 |
Rep 53
Jacking points?
My car has hard plastic rectangular sections (small boxes) where you're supposed to jack the car up. Is there some sort of adapter available for when you're using a trolly jack (the car obviously doesn't have its own jack). I'm worried the round 'claw' on the trolly jack will distort/damage the plastic jacking point. There's nothing in the handbook about it.
10-29-2019, 11:24 AM | #3 |
Rep 3,068
Here you go..... https://www.ebay.co.uk/itm/Rubber-Ja...0AAOSwUYNc5mPQ
Plenty of places to get them from not just as above, have a search. |
10-29-2019, 11:29 AM | #4 |
Rep 786
Drives: 2018 F80 M3 CP YMB
Or just use a suitable off-cut of wood...
Current: 2018 F80 M3CP YMB. Previous: 2015: F34 335d GT M Sport+; 2012: F07 535d GT M Sport; 2008: 335d SE; 2005: 530d; 2003: 330d; 2002: 330i; 1999: 523i
10-29-2019, 02:22 PM | #7 |
Rep 32,881
Depends what the end of the jack looks like. If it's a scissor jack then it would need to fit securely into the jacking points.
10-30-2019, 03:53 AM | #9 |
Rep 757
As said above, a small block of wood will do the job.
Or failing that, something like an old rag, folded a few times to use as a "pad". Swapped over to my winter wheels at the weekend and was done in half an hour. |
10-30-2019, 08:17 AM | #10 |
Barge driver
8656
Rep 12,425
I don't think it's necessary using standard trolley jack just line up the jacking point in the centre of the cup and raise the car no damage is caused.
730d/Z4C
