10-31-2019, 08:16 AM | #1 |
Rep 680
Brake pad change question
Hi all,
Do I need to order two replacement wear sensors? Or can I reuse if they have not activated? Thanks
Current: None
Previous: E92 320d, E92 LCI 330d F30 330d, F32 440i |
10-31-2019, 08:20 AM | #3 |
Rep 8,083
Yes they can be reused but as Digidick says, you need to be careful as heat can make them brittle.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
10-31-2019, 08:41 AM | #4 | |
Rep 32,881
Best to buy one and have it ready when you change the pads as the old one can disintegrate when you remove it. They’re only about £10 on ebay/ecp |
10-31-2019, 08:51 AM | #5 |
Rep 785
Drives: 2018 F80 M3 CP YMB
Or... don't order one and if it does disintegrate just tie it out of the way temporarily until the new one arrives - it is only a case of taking the wheel off again to swap out the sensor... If you use a screwdriver to gently ease it backwards out of its slot keeping it straight you should be fine...
Current: 2018 F80 M3CP YMB. Previous: 2015: F34 335d GT M Sport+; 2012: F07 535d GT M Sport; 2008: 335d SE; 2005: 530d; 2003: 330d; 2002: 330i; 1999: 523i
