BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 Roof bar difference
proTUNING Freaks
      01-31-2024, 10:26 AM   #1
daronk
daronk's Avatar
Drives: BMW 335i
Can anyone tell me the difference between the original 82712295099 versus the newer 82712361814?
      01-31-2024, 06:37 PM   #2
YASBBYM3
YASBBYM3's Avatar
Drives: BMW M4 Cs Lamborghini Huracan
A generation
      01-31-2024, 06:44 PM   #3
daronk
daronk's Avatar
Drives: BMW 335i
Thanks and yes I know that but was curious if the mount was any different like better support and/or protection? Quieter? Etc.
      02-01-2024, 10:04 AM   #4
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
82712295099
Roof rack
F30/34 GEN1
Weight:5.090 kg
Superseded by: 82712361814 (03/10/2015 — ), Bilaterally exchangeable
Fits: F30/F80/F34 (all model years)
82712361814
Roof rack
F30/F34 GEN2
Weight:5.000 kg
Supersedes: 82712295099 (11/30/2011 — 03/13/2018)
Do these details answer your question? Other than being slightly lighter (measurement error of 90 grms if anything), the Gen II should be no different to Gen I.
I use Thule Aero Blade on mine and have no regrets. It is actually more slimmer and more useful imho than OEM as it is a little wider and there are no obstructions at the top, side to side along the whole length of the bars to carry flat pcs (4 x 8 plywood or drywall with 8' supports on the edges).
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      02-04-2024, 10:49 AM   #5
daronk
daronk's Avatar
Drives: BMW 335i
Thanks but that’s all info online and I’ve already seen. My question really comes down to how it mounts to the roof of the car and if the newer one provides any better support or protection. Basically are there any changes to the physical design.
      02-04-2024, 05:39 PM   #6
Oksamit78
Oksamit78's Avatar
I looked through the images of both actual part numbers and I could not see anything significantly different between two. One would need to physically obtain both Part numbers and do more thorough inspection side by side in order to identify differences.
The part number change could be due to change of supplier to BMW, even without any change to actual design of the bars.
Judging by the overlapping time period of 3(!) years, highly likely, both part number are identical. Also, to me, this means that they were manufactured by different suppliers as it makes no sense for the same supplier to be making the two different and nearly identical products under the same roof without confusion in manufacturing lines.
daronk3.00
      03-09-2024, 06:03 PM   #7
daronk
daronk's Avatar
Drives: BMW 335i
Found a deal on gen2 current version thanks for all the info
