      08-25-2013, 10:44 PM   #4445
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Just noticed that there's now psdzdata 50.3 and Esys 3.23.4 - do I need a new token to be able to use the newer version of Esys or will the current one still be good for that?
      08-25-2013, 10:47 PM   #4446
shawnsheridan
shawnsheridan's Avatar
Technically no, but you would need a new Patch, and since they come together, you would get a Token with a new Validity Period.
However, if you already have 3.22.5, there is no reason at all to update to 3.23.4. You will gain nothing.
      08-26-2013, 12:06 AM   #4447
ioschi2003
Drives: BMW X3 3.0
The PSdZData version used is not a matter of being better, rather it is solely a matter of necessity. Either you have a car that was programed with ISTA/P 2.50.3 and you NEED 50.3 PSdZData to read the ECU's and Code them, or you don't, in which case you DO NOT NEED it.
Using newer PSdZData on a car programmed with older ISTA/P version buys you nothing. The car will still only be capable of the features programmed into it from the older ISTA/P version, unless you are going to flash the ECU's with the new 50.3 firmware.
OK Thanks,
I'll check with the new FW after BMW update with 6NR option.
If necessary I'll ask to you for new psdzdata.
bye
      08-26-2013, 02:49 AM   #4448
avgor123
avgor123's Avatar
Russian Federation
Drives: F30 320D Sport
Hi all!
Does anybody know is it possible to change info in serviсe logbook in the fob with E-SYS?
      08-26-2013, 05:48 AM   #4449
shawnsheridan
Originally Posted by samaks View Post
Hello Shawn,
May I have the links to the software also? Just ordered the cable.
You will have to post an email, or wait until you can receive PM's.
Originally Posted by carlos BMW View Post
Dear Shawn, could I please ask for the latest e-sys, data files and instructions as a PM
Thank you!
You have to post an email or wait until you can receive PM's.
Time's up. PM's sent.
      08-26-2013, 11:23 AM   #4450
iaincb
Drives: G01 X3 M40i
Shawn,
Any chance of one more PM with links to the software?
      08-26-2013, 11:36 AM   #4451
shawnsheridan
Originally Posted by iaincb View Post
Shawn,
PM sent.
      08-26-2013, 01:17 PM   #4452
etamitlu
Drives: bmw
Hi, I need help. Such an error in reading FEM-BODY F21, Level F020-13-03-503, have psdzdata 49.4
      08-26-2013, 01:26 PM   #4453
Shinyo
Drives: f30
Shawn can I get one of your PMs with the links? Thanks a lot!
      08-26-2013, 03:27 PM   #4454
Bvt13
Drives: 2016 AW M4
2016 M4  [0.00]
Shawn,
Can I get a PM with all the necessary links?
Thanks!
      08-26-2013, 03:36 PM   #4455
shawnsheridan
PM sent.
      08-26-2013, 03:38 PM   #4456
shawnsheridan
PM sent.
      08-26-2013, 03:39 PM   #4457
shawnsheridan
Originally Posted by Bvt13 View Post
Shawn,
Thanks!
      08-26-2013, 04:02 PM   #4458
schwarzrb
Drives: 2014 328d
1) Read this Post:
http://www.f30post.com/forums/showpo...postcount=4387
2) No. It saves only a copy of your original FA (VO).
3) VO Code each ECU or your entire SVT with original factory FA (VO). DO NOT use the "CODE DEFAULTS" button in E-Sys, or you will regret it.
Shawn, for 3), what are the steps to do this. Is there a procedure somewhere? Thanks!
      08-26-2013, 04:05 PM   #4459
shawnsheridan
VO Code:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
This will encode an entire ECU with all the parameters needed to support every option in your Vehicle Order.
You can VO Code the entire car one module at a time, or you could use Ctrl-Right-Click above and select multiple ECU's to Encode, or you could even Right-Click at the Top of your SVT where your VIN is showing, and encode the entire SVT (all ECU's). If you try and encode DME Module, or the entire SVT (which includes the DME module), the car can not be running during the encoding process.
      08-26-2013, 10:32 PM   #4460
valley_nomad
Drives: 2013 F30 328i
Does TCM_LOGIC_R_OFF_DOOR = aktiv disable FH_TUERAUF_STOP_MAUT = nicht_aktiv?
i.e. If the car is coded to turn off the radio and navigation when the door is open, will it also stop the window up/down regardless the coding?
      08-27-2013, 05:53 AM   #4461
Kapitein Iglo
Drives: F31
VO Code:
Is there a possibility to check what option effects what specific module?
Eg: 6NK -> only HU_NBT, etc
      08-27-2013, 06:29 AM   #4462
shawnsheridan
No. You just have to make an Educated Guess.
      08-27-2013, 09:45 AM   #4463
Yobyot
Yobyot's Avatar
494
Drives: MY19 X3 M40i
It's time up re-code my favorite options because the dealer has updated the car. (BTW, whatever level they used really improved ASS. Some -- not all -- stops are imperceptable. And re-starts are amazingly smooth.)
Could someone review for me the best way to update an older working Windows system (PSdZData 48.3 with ESys 3.18.4) to 50.3 and 3.23.4?
I searched this thread, but it's so large I couldn't find the posts that I think describe a process of simply re-installing ESys (and getting a new token, of course) and overlaying the entire psdzdata folder.
Would that still work?
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
MY19 X3 M40i:
Produced: 2018-08-15; Delivered 2018-08-22
      08-27-2013, 11:09 AM   #4464
etamitlu
Drives: bmw
Shawnsheridan, thanks for your help and patience.
      08-27-2013, 11:40 AM   #4465
shawnsheridan
Start over. Uninstall E-Sys 3.18.4 though the Control Panel, and delete the psdzdata folder (e.g. C:\ESysData\psdzdata). The following the installation instructions as if it was the first time.
      08-27-2013, 11:44 AM   #4466
shawnsheridan
Shawn,
Thanks!
