BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Tires size for 624M
      12-07-2016, 09:36 AM   #1
BulsaraF36
BulsaraF36's Avatar
142
Drives: F36 435i M-Sport
Tires size for 624M
Hi,
what is the widest tires size I can put on OEM 624M wheels?
Currently I have 225/35/20 ET36 and 255/30/20 ET47 and want to replace it with Continental DWS06 245/35/20 Front and 275/30/20 Rear.
Would this setup work?
Thanks!
      12-07-2016, 10:30 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
No, 275 is too wide for the rear 8.5" wheels.
245 front and 255 rear is the widest recommendation, but only works with RWD.
35-profile tires (245/35-20 and 255/35-20) or 30-profile tires (245/30-20 and 255/30-20).
      12-07-2016, 11:09 AM   #3
BulsaraF36
BulsaraF36's Avatar
142
Thanks, guess I will need to find different all season tires or buy a new set of rims.
      10-11-2021, 07:07 AM   #4
sammoorman
Drives: BMW 440i M Sport
Increasing tyre profile on 20" rims - 624m's
Good afternoon,
Just to double check, I have 20" rims (8" on front 8.5" on rear). Presently with runflats (which I hate). However I wanted to confirm the options for tyres i can put on without causing problems for my F36. Are they as follows:
Front: 225/40 r20 or 245/35/r20 or 235/35/r20
Rear: 255/35 r20
Presently running:
Front: 225/35/r20
Rear: 255/30/r20
Will a difference in height between the front and rear cause problems for Traction control, ABS etc? What is an acceptable differential in height between front and rear?
225/40 r20 (front) and 255/35 r20 (rear) seem like a similar side wall height but:
1. Will these fit the wheel arches ok?
2. Will they cause any electronic or mechanical problems for my car?
Many thanks
Sam
      10-11-2021, 04:48 PM   #5
J555
Drives: F31 LCI 340iX
Originally Posted by sammoorman View Post
According to my calculations 225/40 r20 and 255/35 r20 is close but:
No, the overall diameter is way too big for your car. The options you have are:
- 225/35/20 + 255/30/20 (obviously)
- 235/35/20 + 265/30/20 (more sidewall, more grip, the rear tires will bulge a bit)
With your current 8-8.5" wheels, you shouldn't go wider.
No, not all.
      10-13-2021, 10:44 AM   #6
sammoorman
No, not all.
Thank you, much appreciated.
      10-14-2021, 11:11 AM   #7
5w20
@_sunbish
5w20's Avatar
282
Drives: Bmw 435i & 340i
Originally Posted by BulsaraF36 View Post
Hi,
Thanks!
I use 225/35/20 (26.2") and 265/30/20 (26.3"). The Michelin Pilot 4s in the 255/30/20 (26") size would stretch on the rear and I didn't like that. The 265 width is more square and better resembles how the 225's look on the front. In my opinion, go with 265 in the rear. Keep in mind different tire models and different brands will fit different.
