01-13-2017, 01:33 AM | #1 |
Happily breaking in the F36!
74
Rep 72
Trunk height 4series GC, parking garages?
So I noticed the trunk opens like the mouth of some giant mythological creature. It's massive. Brilliant in 95% of times, easy to get into and actually tall enough for a 6'1" guy not to hit his head.
But... What if I open it in a parking garage? How can I stop it from opening all the way? Will it work to just force stop it with 'hand-power'? |
01-13-2017, 05:02 AM | #2 |
Rep 881
If you place your hand at the height were you'd want the trunk to stop opening, even without exercising too much pressure, it will stop.
Same goes for closing of the trunk. I don't know if it would be possible to program a max height as default. |
01-13-2017, 05:13 AM | #3 | |
74
Rep 72
As for your question about programming; yes, there is an option in the menus to specify maximum opening height. But I dont want to go into options somewhere every time i am in a parking garage and then change it back for normal use. |
01-13-2017, 05:57 AM | #4 |
Rep 72
Im going to have to try this again. When I was in an underground garage for the first time with my GC and opened the hatch, it took quite a bit of effort for me to stop the lid from going up all the way. I thought I was going to rip off my spoiler.
Doublep74.00 |
01-13-2017, 06:28 AM | #5 |
74
Rep 72
I also suspect that opening the trunk with the trunk switch near the license plate and then pulling it open, will do it. I did that, and you basically have to pull hard for each inch to open...
01-13-2017, 06:41 AM | #6 |
Rep 470
When you open it and kick under the bumper try to kick it a second time at the height you want it to stop and see if that works. I am not 100% certain so try it outdoors first.
01-13-2017, 06:45 AM | #7 | |
74
Rep 72
However, perhaps pressing the button on the remote a 2nd time will work... |
01-13-2017, 06:52 AM | #8 | ||
Rep 470
Doublep74.00 |
01-13-2017, 07:46 AM | #9 |
Rep 72
With my spoiler, the hatch lid stands at almost 7 feet when fully open.
01-13-2017, 07:47 AM | #10 |
Rep 72
01-13-2017, 07:56 AM | #11 |
74
Rep 72
But the button on the trunk hatch will close it from any position, I assume?
01-13-2017, 08:05 AM | #12 | |
Rep 4,451
Drives: '23 X1 28i xDrive
01-13-2017, 08:23 AM | #13 | |
74
Rep 72
Most commercial garages are ok, if you park front in first. However, quite a few are lower at the end of the spot, so if you park ass in first, it will damage it. I previously had an Alfa Romeo Giulietta and I damaged the trunk door in the first month by carelessly opening it in a parking garage. Once you've recovered from my artistic talent, you can see in the drawing below, what I mean. The red hatch is parked front-end in, it's fine. The blue 430iGC is parked ass-in, which poses a problem... |
01-13-2017, 08:33 AM | #14 |
Rep 1,148
Chris Bangle is that you ? |
tex26702412.50 440xiGCMsport208.50 |
01-13-2017, 08:36 AM | #15 |
Rep 4,451
01-13-2017, 08:40 AM | #16 |
74
Rep 72
Yeah. no. My personal garage is so small and filled with bicycles (we are Dutch, after all) that no car fits in it. This would be describing a public garage.
You got me! |
01-13-2017, 11:02 AM | #17 | |
Rep 72
01-13-2017, 07:02 PM | #19 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
^^^ this.
I have mine set to just open exactly even with the car roofline so its a straight line. This way, it doesn't smack a shelf in the garage........
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
01-13-2017, 07:10 PM | #21 |
Rep 564
BTW, I did not see this mentioned anywhere but the opening height of the hatch can be adjusted in the iDrive. I think it has 5 different steps from all the way open to "much smaller opening".
If you remember to change the hatch height you wont have to do the double button press thing. I tested this out on my 435 GC (2016) because I was worried that the "full open" height would be so high it would be in the track of my garage door at home. It wasnt, but I set it to the least amount of opening and tested each step till I saw exactly where they stopped. Hope that helps you. |
01-14-2017, 12:22 AM | #22 | |
74
Rep 72
