BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Correct PSI to run with F30 20" 624M or 405M wheels
      04-14-2020, 08:08 PM   #1
876_F30_335i
Drives: F80 M3
Any idea of the correct tire pressure to run with these 624M or 405M wheels - 225 35 20 front / 255 30 20 rear. Anyone have the oem sticker on the door for these tire sizes ?
I have a sticker on the door of my car that shows 36 psi front / 41 psi rear for 245 / 35 / 20 front and 275 /30 / 20 rear however those arent the tire sizes for these wheels.
dakar_f31108.00
      04-15-2020, 02:23 PM   #2
weehe126
Drives: 2017 340i
You should set the tire psi based on use. That is why they have the little arrows, if you aren't scrubbing down the the arrows your psi is too high. The door sticker is also meant cor RFT in most cases.
      10-18-2021, 12:17 AM   #3
tajmahal
Drives: BMW F30 335i Msport MPeformanc
Here bro as per bmw manual:
bmw tire pressure 335i
up to 100mph
225 35 r20
psi 38
255 35 r20
psi 44
over 100mph
225 35 r20
psi 42
255 35 r20
psi 49
      10-19-2021, 11:23 PM   #4
djacinto
djacinto's Avatar
Drives: F32 428i Xdrive
2014 BMW 428i xdrive  [0.00]
2013 128i  [0.00]
up to 100mph
225 35 r20
psi 38
255 35 r20
psi 44
over 100mph
225 35 r20
psi 42
255 35 r20
psi 49
Does it mention if it's for rft or go flats?
Also what section of the manual is that found in?
-2014 F32 428i Xdrive "Bella"
Follow the build!
-2013 E82 128i "Austin"
Follow the build
EuroFever
