BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 2 sets of Style 403 wheels make 2 square wheelsets?
proTUNING Freaks
      10-04-2021, 03:05 AM   #1
Xanderf31
Drives: F31 330D X BMW
Hi,
I have 1 set of BMW style 403 wheels
specs
Front wheels 19x8" ET36 Tyre 225/40/19
Rear wheels 19x8.5" ET47 Tyre 255/35/19
I was wondering if it's possible to buy a second set of these wheels and run square setups for winter and summer.
Running square with 8" ET36 shouldn't be a problem?
I think in order to run the 8.5 ET47 on the front i would need a spacer of 10mm.
Can someone confirm that this is right?
grtz!
      10-14-2021, 12:50 AM   #2
DLag30
Drives: F80M3 & F36
I have done something similar. The FRONT 19x8 et36 square will definitely work on all corners. Your biggest issue would be the front strut and rim clearance with the REAR 19x8.5 et47. I would personally run 12mm spacers on the front when running the REARS. Some 10mm spacers have fitment issues with the hub.
403 square staggered
