10-18-2021, 05:07 PM | #1 |
Rep 17
New tires on 19x8.5 and 19x9.5 on F34 xdrive
HELP! I tried to look for this topic in the forums but I didn't find anything that addresses my current issue. So here I am. I recently replaced my RFT's on my F34 xdrive to regular tires in hopes of a quieter ride. I got a really good deal on a set of staggered replacement 405M wheels that are 19x8.5 et34 and 19x9.5 et40. According to my research as long as I stay within a 1% rolling diameter difference, it should be ok. I bought Yokohama Apex 235/40r19 and 265/35r19's at Discount Tires and they look like a great fit. This setup gives a difference of .4% which is well within the 1% acceptable difference. However, I feel slight jerkiness upon accelaration. Can this be resolve with tire pressure? If so what tire pressure should I set them? The door panel says 32 in front and 35 in back, but I assume that that's for the OEM 2258/50r18 tires? I can exchange the tires for 235/35r19 and 275/30r19 which will bring the difference to 0%, but it will lower the height down to 25.5". Will that still be ok? Your input are great appreciated.
10-19-2021, 12:03 AM | #2 |
Rep 4,333
regardless of wheel diameter, on F34 the standard OEM tire diameter is 27". 235/40/19, 265/35/19 is fine for x-drive but increases speedo/odometer error and wheel gap. 235/35/19, 275/30/19 is also fine for x-drive but will exacerbate the speedo/odometer error and wheel gap further.
imo the tire sizes you should be using are 245/40/19(26.7") & 275/35/19(26.6") or 225/45/19(27") & 255/40/19(27") or 235/45/19"(27.3"), 265/40/19(27.3"), not much selection in the last size combo, though. btw, 19" 405M OEM wheel specs are 19x7.5 ET45, 19x8 ET52 for 2-series. you have replicas of some sort. . Last edited by alohasurftoad; 10-19-2021 at 12:15 AM.. Reason: added info about 405M |
10-19-2021, 06:07 PM | #3 | |
Rep 17
Update: Today I adjusted the tire pressure to 34 in front and 37 in rear and it seemed to help with the jerking. It's still there once in a while, but not as pronounced as before. I'm a middle age woman who is learning so much about wheels and tires, and I'm kinda enjoying it. Thank you for all your help. |
alohasurftoad3081.50 |
10-19-2021, 06:34 PM | #4 |
Rep 17
Does anyone have 235/45r19" front, 265/40r19 rears in their 3 series GT? Can you post pictures here please? I have 235/40r19 and 265/35r19's Yokohama Apex on mine and they look good, but there's a little bit of jerking so I'm debating if I want to keep adjusting the tire pressure until I find the setting where the jerking disappears, or do I just want to replace them with the 235/45/19"(27.3"), and 265/40/19(27.3") that Alohasurftoad suggested?
