BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Tires for 405m on F36 xDrive Gran Coupe
Studio RSR
      10-22-2021, 04:34 PM   #1
juicehound
Drives: 2015 BMW M4
hey all just hit a manhole cover and blew out tires and 7k+ suspension damage later - time to lose the awful run flats and go with Michelin AS 4 tires but I need some help with tire options.
Car is an unmodified 2017 440i x-Drive Gran Coupe F36 w/ the BMW 405m 20" wheels:
https://www.shopbmwusa.com/PRODUCT/4...--COMPLETE-SET
I want the MOST sidewall I can manage without rubbing - problem is I don't know what the maximum diameter (height) tire setup I can run on the 405m's
using this tool here I came up with the following options: https://tiresize.com/calculator/
Options (Diameter smallest to largest):
square 235/35/20
square 245/35/20
staggered 245/35/20 + 255/35/20
square 235/40/20
square 245/40/20
please help me on this thank you so much!
      10-24-2021, 09:03 PM   #2
juicehound
Drives: 2015 BMW M4
anyone?
      10-25-2021, 07:34 AM   #3
cfm56d7b
While 20" 405M wheels look great, there isn't enough sidewall (run flat or go flat) to overcome the pot holes in the North East.
The best option: 18" wheels with the right tires.
Compromise: 19" wheels. I drove in the North East on 19" wheels and OEM staggered tires without major issues. Several pot hole encounters where alarming but no suspension or wheel damage.
      10-25-2021, 11:03 AM   #4
juicehound
Drives: 2015 BMW M4
I agree with you but staying with the 20's my question still remains unanswered.
      10-25-2021, 11:22 PM   #5
ade555
Drives: BMW F36 430D
I'm not a expert but looking at the link for the wheels fronts are 8j and rear are 8.5j so how you planning to achieve square setup?
I run 405 reps in 8.5j front and 10j on rear with tyres 235/35/20 and 275/30/20 on 4 series GC, from personal experience the front sidewall high is not enough, looks good but you can feel every stone and for that reason I'm going down to 19" but I will miss the look.
Front on 20s I don't think you can go higher then 235/35/20 as there is hardly any room left but I do have 8.5j with slightly different offset to yours, on rear you can get away with larger wheels and tyres.
      10-26-2021, 08:17 AM   #6
juicehound
Drives: 2015 BMW M4
thanks for this - do you have x drive?
it's so tough b/c there's SO many variables when it comes to these things - if you change one you have a question in your mind as to what is possible and what's not going to work
      10-26-2021, 11:43 PM   #7
ade555
No my RWD with m sport suspension. I didn't lower the car and been honest on front there isn't much space to do so. I can pm you some pictures later today.
