12-23-2017, 07:06 PM | #1541 | ||
Rep 3,659
Drives: 981 Cayman GTS
12-23-2017, 09:15 PM | #1542 | |||
Rep 6,218
M3 Adjuster7905.50 |
12-23-2017, 09:17 PM | #1543 | |||
Rep 6,218
12-23-2017, 09:32 PM | #1544 | ||||
Rep 3,659
M3 Number 863221.00 |
12-23-2017, 10:27 PM | #1545 | ||
Rep 11,785
I Autocross and track with both 275/35 18 and also 285/30/18 all around on my 1M. When I borrowed a friend's 10.5" rear wheels with 315/30/18 at the back that's when I realized Wow my car is finally actually getting all the power down! I've got a Measly 335hp and just 365! Ft lbs .. : |
12-23-2017, 10:34 PM | #1546 | ||||
Rep 14,115
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
12-24-2017, 07:59 AM | #1547 | |||
Rep 11,785
If you can manage to fit 315s out back , yours won't slip any more at all in first. . I'm also confident you will *then* realize that you aren't actually getting all the power down currently. Ask me how I know. Lap times with DSC off should definitely be quicker than MDM as the latter mode employs braking of the rear wheels , along with reducing the power of the motor to maintain traction at the rear. A person that drives very smoothly can avoid the car using the brakes at the rear but usually the power being backed off is still an issue. For example at Barber Motorsports park, for me coming out of the esses onto the back straight you absolutely need 100 percent power but the car will never let you get full throttle in MDM mode because one needs to accelerate from the apex to track out and the car is at an angle still. It's one of those places where more power actually helps you as a driver, and the car is still backing out of the throttle. I would imagine coming out of the corkscrew at lacuna would be similar. |
M-Pilot4859.00 |
12-24-2017, 08:07 AM | #1548 |
Rep 6,673
So 475 target bhp on the S58 will pretty much dyno 502-510 bhp. Wow. Because the S55 M3 already had no problem putting the power down to the wheels.
Can’t wait for the “2019 M3 leaving cars and coffee” videos!!! |
12-24-2017, 08:17 AM | #1549 | |
Rep 6,673
We know the S58 “475” bhp will almost certainly dyno at 500+ out of the box. What’s in a number. |
12-24-2017, 09:55 AM | #1550 | ||||
Rep 14,115
12-24-2017, 10:15 AM | #1551 | |||||
Rep 11,785
In practice, I've seen drivers be smooth and fast and some drivers are tail out , appear to be overdriving but actually are in full control. Ever seen Pierre kleinubing driving a Real Time Acura or any Honda inspired FWD product ? Contrast that with co driver /team owner Peter Cunningham or a driver like BMWs own Bill Auberlen who are fast and smooth lap after lap. Any form of stability control will affect one of those drivers more than the other because of driving style. |
12-24-2017, 12:51 PM | #1553 | |
Moderator
29419
Rep 13,107
///M is art ↔ Artemis
12-25-2017, 10:48 AM | #1555 |
Rep 7,594
Drives: '19 M2C
All that power and I will still be unhappy....
Because BMW will make the 3 series bigger yet.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
12-25-2017, 03:45 PM | #1557 | |
Rep 1,374
nothing but a "tuned" S55. The F8X gen sounded terrible, M4 GTS sounds terrible. I probably heard 5 quality aftermarket exhaust including M performance on F8X, there's no difference . It's the same "noise", just got louder and hence unpleasant. and this is at idle. This engine sounds terrible at driving too...
12-25-2017, 05:45 PM | #1558 | ||
Rep 1,048
2019 Jeep Wrangler | 2018 BMW 320i | 2016 Porsche Boxster Spyder | 2009 Jeep Wrangler
gone: 2015 M4, 2015 335i, 2012 Turbo S, 2008 M3, 2004 M3, 2003 330xi |
Penguino1605.00 |
12-25-2017, 07:44 PM | #1559 | ||
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
12-25-2017, 09:52 PM | #1560 |
Rep 4,128
Drives: M235i & G30 540i
The M2 is the new M3. Get that one if you want a smaller size.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
12-26-2017, 06:58 AM | #1561 | |||
Rep 1,644
12-26-2017, 07:44 AM | #1562 |
Rep 7,594
Drives: '19 M2C
I have one. Went from an e92 M3 to the M2. Reminds me of my e46 M3.
