02-26-2021, 03:23 PM | #1 |
Rep 16
HPFP drops mid range
Hi guys. I have a 435xi MPPK DINAN stage 2 with Dinan carbon cold air intake, custom downpipe, VRSF chargepipe, MASATA boost pipe, MASATA UHD stepped cooler and Mosselman turbo oil thermostat.
Yesterday i was at the dyno and we got 382 hp at the crank. Not a bad number but i didnt like the power delivery and I wanted a custom tune. So we managed to get 330 whp with his map on a bypass mode. When we tried to use stage 1 Dinan the could not keep up with the fuel so he said that he is going to work some more on his tune to get araound 420-440 HP to the crank. With the new flash the car started to lose power around 3.5-4k RPM. We tried different maps but the result was the same. We flashed the map that we got 330whp and the result was the same... not enough fuel. After that with the stock map the car had no issue at all... After few more hours we could not solve the problem. We noticed that around mid range the fuel drops from 150-200 bar to 60 - 5th gear full power . The car works fine till we try to dyno at 5 gear, its the same on the road... Can anyone help? |
02-26-2021, 03:41 PM | #2 |
Rep 7,607
Why are you mixing whp and crank hp numbers? What correction factor did you use to go from whp to crank hp?
I am assuming you are talking about the older Dinan piggyback? or are you talking about a dinan flash? The interaction between your custom tune and the Dinan isnt clear. I am assuming your tuner was logging - post the logs. In any case, if your HPFP pressure was crashing you already know what the problem is. Are you running pump gas? Whats the ethanol % in Bulgaria? How much boost are you running? Whats the octane? I'm not sure what kind of help you are looking for. |
02-26-2021, 04:02 PM | #3 | |
Rep 16
I am talking about the old piggyback. He made the custom tune on the stock ECU. I am runing SHELL V POWER RACING which is 100 RON The boost i think was from 1 to 1.2 bar. He noticed that when he make it to 1 bar on live data we see that the car make 1.2 bar on the bypass mode on the DINAN tune. We took it completely off the car and the result was the same... |
02-26-2021, 05:00 PM | #4 |
Rep 7,607
That power loss seems excessively high but not relevant to your issue.
The main question that still remains is what the ethanol % of your fuel is. 1.2 bar is about 17.5 psi which should be OK for pump gas (0-10% ethanol) but its getting up there in boost. People can usually run that much though without crashing the HPFP. I have gotten up to 16.5-17 psi with E30 without a HPFP crash, but that's at the limit really. If you are overboosting it seems there is a problem with the tune or a hardware problem. You shouldn't be exceeding boost targets by 2-3 psi without throttle closure or other protection kicking in. I assume you are correctly looking at MAP boost and not pre throttle? Pre throttle boost can/will be over target if there is throttle closure. It's possible you also have a HPFP problem, but its mechanical, so quite unlikely. LPFP issues are similarly uncommon and the LPFP limit is much higher than HPFP. I would probably need to see a datalog to provide any more insight. |
02-26-2021, 05:27 PM | #5 |
Rep 16
No idea what the ethanol % is... At the gas station when filling up the car i noticed that there is E10 written on the pistol... 1 - 1.2 bar is the turbo boost.
I have also noticed that when i ran stage 2 /before the custom tune/ around 160-170 km at full throttle the car loses power completely. I used those cleaning products which are for fuel injection system changed the spark plugs with NGK 97506 0.20” gapped and i think this problem disappeared after few hundred km. Could it be a problem with fuel injectors or igntion coils? |
02-26-2021, 05:30 PM | #6 | |
Rep 7,607
Fuel injectors could affect HPFP pressure, but it would need to be a situation like an injector being stuck open (i.e., flowing too much fuel). Again, I need to see datalogs to see exactly what the car is doing. But it sounds like you don't have those? |
02-27-2021, 01:39 PM | #8 | |
Rep 7,607
Not sure how much help i can provide without logs, that's really the source of information. |
02-27-2021, 02:17 PM | #9 |
Rep 16
Tuesday we are going to give it another go and if we dont make it properly i will ask him for the datalogs. Today i tried full throttle 4th gear and fuel rail pressure was 2810 psi. 5th and 6th gear remaind the same but no on full power.
02-28-2021, 12:49 PM | #10 | |
Rep 7,607
If your HPFP is still crashing, just have him dial back the boost a little bit and consider adding more timing to make power if you are running high octane fuel that can support it. |
#customtune, #hpfp, #low fuel pressure, #n55, #tune, ecu bmw tuning, f3x |
