07-27-2014, 10:25 AM | #1 |
Rep 157
Whats the difference between 180kw N20 and the 135kw version?
As far as I can make out, everything about these two engines are identical bar hp and torque. So are 420i owners an ECU flash away from unlocking a "428i" or is there something I'm missing?
http://en.wikipedia.org/wiki/BMW_N20 http://www.bmw.com/com/en/newvehicle...i&model_2=428i |
07-27-2014, 09:25 PM | #2 |
Rep 1,424
Drives: '23 i4 M50, '15 M3, '18 911
Yes, you can tune the less powerful engine to get it up to as much power as the 28i engine. But you will be voiding your engine warranty if you care about that kind of thing. The internals of the engines are different, so they aren't "identical".
07-27-2014, 09:49 PM | #3 | |
Rep 1,490
Both engines can be modded to produce more HP than their stock numbers. A modded 20i will be at stock 28i numbers (maybe an additional 10-15 HP), and a modded 28i will be at stock 35i numbers (maybe an additional 10-15 HP).
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
07-28-2014, 05:34 AM | #4 |
Rep 157
Do you know what exactly is different ? I'm just curious as to how BMW managed to extract 60 more HP and 80 Nm of torque.
07-28-2014, 06:18 AM | #5 |
Rep 39
The 3/420i variants of the N20 have different pistons. I believe that was done to increase the compression ratio (10:1 vs 11:1). In addition, the PSI is much lower (8 vs 18).
It can be tuned to be similar HP, but be careful because the higher compression ratio will not handle the same amount of boost. - Jason |
07-28-2014, 06:35 AM | #6 | |
Rep 157
Btw I don't have a 420i, I've put down an order for a 428i. I was just curious as to how the 428i has so much more HP and Torque. |
