BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 2014 N55 update and JB stage 1
      07-19-2013, 01:51 PM   #1
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
2014 BMW 335 Xi  [10.00]
anyone with 2014 335 install JB stage 1 and can confirm compatibility
thanks!
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      07-22-2013, 06:14 AM   #2
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
i knew some 14's have hit the states already, no one modding?
      08-01-2013, 09:19 AM   #3
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
bump!
      08-01-2013, 10:53 AM   #4
tdizzle
Drives: 2017 F80 ZCP
No reason to believe it wouldn't work. Same engine. Stage 1 is exactly the same even in the older body style with the N55 (and it works in 535s with the same engine too...)
      08-01-2013, 11:34 AM   #5
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
the reason i asked was because BMW discontinued PPK due to engine software upgrade, so playing it safe
      08-02-2013, 12:22 AM   #6
verbs
Drives: 2015 M235i
Uh, why don't email the company (Berger) and ask?
      08-02-2013, 05:56 AM   #7
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
already did, they say that nothing changes but they did NOT test on 2014 car
      08-02-2013, 08:37 AM   #8
tdizzle
As I've said, there is no reason apparently that anyone can think of why it wouldn't work. It is totally different from the PPK in the way it works, i.e., it doesn't care which DME your car came with. It worked with the old DME in the 2011s, the 2012s, and the 2013s even when the PPK required updates/new versions to work.
It's a piggy back tune that works in multiple applications of the N55. Which is also why it works in both the F30 and F10 verisions along with the late model E9X with the N55. But feel free to wait until someone else tests it if you like.
I have a suspension that BMS won't bother testing on a '14 specifically unless someone drops one off for kicks.
      08-02-2013, 09:20 AM   #9
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
makes perfect sense, thanks!
      08-04-2013, 09:07 PM   #10
BoostAddict
Drives: SGM 335i
You should be good to go. I don't think there were any major changes to make it not work.
