03-05-2015, 11:05 AM | #45 |
2020 Z4 M40i - 2022 M4C Convt
3124
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Been using it for years on 5 different BMW's no issues with the fluid level warning?
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
03-05-2015, 04:53 PM | #46 |
Rep 285
03-05-2015, 05:43 PM | #47 |
Rep 345
No issue here. Just buy whatever is available to keep window clean. I don't go by the sensor because it always comes on when you're not in a position to buy any fluid. Top it off based on usage. Sometimes it's more other times it's less.
Guess those who need the sensor are also the ones who love the fact there isn't a dip stick. |
03-05-2015, 08:02 PM | #48 |
Rep 4,323
The blue stuff is all the F30 reservoir sensor will recognize, which was fine with me - cheap and easy!
03-06-2015, 07:03 AM | #49 |
Rep 876
03-06-2015, 07:08 AM | #50 |
Rep 4,439
Drives: '23 X1 28i xDrive
03-06-2015, 09:17 AM | #51 |
Rep 4,323
If you search, you'll see 90% of the board had to have their reservoir sensors replaced because they used RAINX or some other non-blue washer fluid.
The blue stuff works with the 2012-13 F30 3-series...unsure if BMW updated the sensors for 2014+.
03-06-2015, 12:24 PM | #53 | |
e92 - 335i
179
Rep 743
The fluid I pulled out of mine was green and I have always had the dealer fill it. |
03-06-2015, 02:29 PM | #54 |
Rep 1,733
When you fixed the problem...that globbed up strainer you showed...did you just have to cleaned that out, maybe soaking it in alcohol or something? I'm guessing that's at the bottom of the tank and you had to remove the whole thing to get at it?
03-06-2015, 03:30 PM | #55 |
Techy
Rep 39
This is my 3rd BMW and I've heard of the rainx issue for some time. I didn't have an issue with the previous two, but this one happened on the first fill.
And to those who say this is a first world problem... We drive BMW's, and we are here to discuss them, any issue we bring up is a first world problem. We are lucky to be able to experience driving such machines. Wiper fluid not working correctly and detecting levels when roads are wet from sand and ice from snow is a problem. It will impair your vision to the point you can't see out the window. I'm also shocked that a dealer in a cold weather climate would fill the car with wiper fluid that could freeze. |
03-06-2015, 03:52 PM | #56 | |
e92 - 335i
179
Rep 743
03-07-2015, 07:15 AM | #58 |
Rep 2,101
While I did get the low fluid level warning when I used to use rain-x, I definitely never had to replace any sensors. Once I switched to a different fluid I no longer had any false warning lights.
2013 BMW 328i xDrive Sport Line Mineral Grey on Everest Grey |
03-07-2015, 07:23 AM | #59 | |
The Ox
91
Rep 319
03-07-2015, 08:12 AM | #60 |
Rep 16,054
Chances are your older cars used a float to detect the fluid level. The newer models use electrical sensors. The change was probably made because in general electrical devices have a lower failure rate and longer life than mechanical devices, and in testing obviously BMW didn't encounter any issues with the fluid that they sell. Needless to say they didn't test the new sensors with RainX.
03-07-2015, 10:37 AM | #61 |
Rep 1,363
Dish washer soap is great for ceramics like cups plates etc but harsh on clearcoat and other car coatings. Suggest sticking with window washing fluid.
03-07-2015, 01:03 PM | #62 | |
Rep 473
Drives: 2016 Mini Cooper S 5 Door
2015 X5 xDrive35i M Sport, Black Sapphire on Terra Dakota Leather, Lane Change Warning, Lighting Package, 6WB, ConnectedDrive Services... (Sold) 2016 Mini Cooper S 5 Door Fully Equipped. (Sold)
2016 Audi A6 35 TFSI 2017 X6 xDrive50i Pure Extravagance, Space Grey on Coral Red, Fully Equipped. |
03-07-2015, 02:15 PM | #63 |
Rep 1,616
What does the sensor do? Just tell you when the fluid is low? Seems pointless.... I know it's "low" when I try to use it and nothing comes out lol. But then I rarely ever use it. :
03-07-2015, 02:22 PM | #64 |
Rep 4,439
04-08-2015, 06:34 PM | #66 |
Rep 1
Hey, I feel bad for bugging you about this but I haven't been able to find any walkthroughs or information on replacing/cleaning out the washer reservoir for an F30. I believe I'm having the same problem as you did; my reservoir is empty but won't fill, as if it's plugged up. I've been using RainX since the car was new so after reading about your problem I wouldn't be surprised. Would you mind pointing me in the right direction so I can figure out how to access and disassemble the reservoir? Thanks in advance, Kyle.
