01-21-2018, 03:03 PM | #1 |
Rep 87
F30 coding
Hi all,
Just joined the forum, already blown away with what you people get up to modifying and changing things on the bmw’s. I have a 2013 f30 saloon and have been reading the info regarding the coding of different things etc. I would like the Bluetooth enhanced and the Apple car play if poss, I have got the top spec sat nav unit widescreen. Been looking at bcables? Kind regards |
01-21-2018, 05:39 PM | #2 |
Rep 565
Get an ENET cable or adapter, download eSys software and check out the coding forums for more info.
02-21-2018, 11:58 AM | #3 |
Rep 1
Hi. I've got the same issue as you. I can only answer calls through the bluetooth and would also like the enhanced bluetooth. Is there a way to check if your car is compatible with it?
I was reading that its possible if you have a combox in the boot of the car(which i think i do) |
02-21-2018, 12:42 PM | #4 |
Rep 765
If u have the combox in trunk or nbt then yes possible. Code 6nh to 6ns.
Look in trunk under the lining and see if u have two boxes. One being fuse box the other is on left side n would b combox. |
