BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DVD playback - file request
      11-19-2012, 03:06 PM   #1
ilhan1103
ilhan1103's Avatar
Drives: f30 318 2012
2012 318D  [0.00]
Could anyone with an f30 (even f10 would be sufficient) who has DVD playback send me the ncd file for your HU CIC?
I wish to compare some values in order to get it working on my car
Thanks in advance
      11-19-2012, 03:40 PM   #2
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
It been tried many times.. impossible i have heard but you code the car to do DVD in motion its easy..
my 4yr old daughter loves it. She can watch disney movies while i drive now.
M Sport Line Estoril Blue
      11-19-2012, 03:44 PM   #3
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
what do you mean? its impossible, yet you have it enabled in your car?
      11-19-2012, 03:48 PM   #4
john08135i
john08135i's Avatar
Sorry i thought you meant a copy of the DVDinMotion dvdrom to fix the video in motion.
You adjust 3 parameters on the car. Its on the cheat sheet on page one.
F10/F11 X HU_CIC 3000 HMI SPEEDLOCK_X_KMH_MAX value = FF 3_kmh = 3 or 8_kmh = 8 Disable DVD Speedlock - Part 2
F10/F11 X HU_CIC 3000 HMI SPEEDLOCK_X_KMH_MIN value = FF 3_kmh = 3 or 8_kmh = 8 Disable DVD Speedlock - Part 1
F10/F11 X HU_CIC 3000 HMI VIDEO_NUR_MIT_HANDBREMSE nicht_aktiv / Werte=00 aktiv / Werte=01 Video just in combination with handbrake. Use w/ above SPEEDLOCK_X_KMH_MIN and SPEEDLOCK_X_
      11-19-2012, 03:53 PM   #5
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
Thanks mate but I got those. I'm just exploring and wish to compare some values, other then these. enabling in motion is not my issue
ah and i see just now what you meant. Does that guys dvd really work btw?
      11-19-2012, 03:54 PM   #6
john08135i
john08135i's Avatar
Yes it works. What are you trying to do?
      11-19-2012, 04:08 PM   #7
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
trying to figure out if its possible to enable dvd playback at all in a car who doesn't have it from factory. You'd think there is no dvd player in it, but the bmwvin.com indicates in the options that the regio code for his dvd is set.
that made me believe it could perhaps be coded.
I have found a shitton of things in the nds that COULD be used for this and could go over them one by one OR if some kind soul lends me his file I can compare.
Just to be clear, I can't do anything weird to you or your car by having your file
      11-19-2012, 04:46 PM   #8
demge01
demge01's Avatar
Drives: F30 320ed
In BMWVIN.com my car too has:
S698A AREA-CODE 2 Area-Code 2 for DVD
But I'm not aware that my car has a DVD player!
      11-19-2012, 04:49 PM   #9
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
Navi updates are on a dvd, so I'm inclined to say it has to have one.
cant check it today the cars not here, but I think we can make sure with a dvd containing burned mp3s.
      11-19-2012, 04:59 PM   #10
demge01
demge01's Avatar
Drives: F30 320ed
I don't have nav.
A quick search of all settings to do with DVD in the HU for me:
SPEEDLOCK_FREISCHALTMENU (nicht aktiv)
CDMM_DVD_AOP_AUTOMATIC (nicht aktiv)
NAVI_FLEET_MODE (nicht aktiv)
CDMM_DVD_SINGLE (nicht aktiv)
CDMM_CHANGER (nicht aktiv)
AREA_CODE_DVD (area code 2)
MULTICHANNEL_MMC_DVD (nicht aktiv)
DVDAUDIO_AOP (aktiv)
DVDVIDEO_AOP (aktiv)
HU_INTERNAL_VIDEO_PLAYBACK (werte 255)
RSE_INTERNAL_VIDEO_PLAYBACK (werte 255)
EXCL_MULTICHANN_FRONT_DVD (nicht aktiv)
EXCL_MULTICHANNL_REAR_DVD (nicht aktiv)
      11-19-2012, 05:08 PM   #11
ilhan1103
ilhan1103's Avatar
2012 318D  [0.00]
I found a few more, but just looking at this:
Multichannel (or maybe i mix it up with another) shows up dvd in the media button?
dvdvideo_aop its aktiv
hu_internal video playback sounds promising.
that is why i wanted someones file that has dvd working.
I guess i can check those 1 by 1.
      11-19-2012, 10:41 PM   #12
zibawal
Drives: 2012 X5D
Would any one have DVD in motion file for e70 2012 and. E93 m3?2010
      08-14-2017, 09:59 PM   #13
aalucca
Drives: 320 GP
code rear dvd in f20
hello guys, could you help me figure out how to watch dvd on rear sets at f20 using front dvd device?
when im on rear sets and select "front drive" shows me a message that's not able to play because dont have disk.
i think i have to change something in code to work
baiscally at this time, i can not see at rear sets the mirror from the front dvd disk.
      02-03-2019, 05:57 AM   #14
nathan340i
Drives: BMW 340i
Could someone confirm the requirements for DVD and Video playback please?
I have a 2015 340i UK model and i popped a DVD into the headunit and it wont play. I also wont play video from a USB in either avi or MP4 i have bimmercode and switched on video via USB, all codecs are on but still nothing
      02-03-2019, 07:09 AM   #15
cjn
Drives: 2021 F40 M135iX
It does rather look as if you have a CD player, not a DVD player. True for my 2014 car, with 606 Business Nav, and I can't play any video by any method. Have you tried playing AUDIO files burned to a DVD? If that doesn't work then you're definitely out of luck.
