01-02-2018, 05:36 PM | #1 |
Rep 42
Drives: 2014 BMW 428i XDrive
No brakes, I mean ZERO
I have a R title 428i XDrive with 23k miles. Temp @5am was about 7 deg. F.
I back out in driveway, stop and head up long driveway, light brake a bit, turn on road, drive 1 block, light brake, turn on road. I forgot lunch so I decide to turn around. Drove less than 5 to 7 min. I try to stop and I think it started to brake, then nothing. I think I used my E brake to stop. I release E brake and have foot on brake pedal and I start to move forward. I believe the ABS light came on at that point. I run car around, drive down hill on my driveway and into to my garage using brake pedal to stop. Shut car off and locked it as I go in house. I then drove to and from work with hand on E brake. Brakes seemed to work both ways. Any idea what would cause a complete brake failure? Is there a sensor or motor or do I just likely need a brake fluid flush? Any idea what the cost is? |
01-02-2018, 07:41 PM | #2 |
Rep 1,560
I would check the fluid, but was it possible you were on black ice?
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
01-02-2018, 07:48 PM | #3 |
Rep 113
I have to say that I noticed today my brakes were not nearly as effective in this extremely cold weather, worse on Monday. This is after driving about 40 miles, highway and city. Never noticed that in my old e60
01-02-2018, 10:15 PM | #6 |
Rep 247
It would be helpful to note how far down the brake pedal went and what kind of pressure you felt. Did the pedal go to the floor? Did it feel like the brakes were engaging, but not stopping the car? Did you press down hard?
01-03-2018, 02:50 PM | #8 |
Rep 641
Thanks. I'll send you a list of other things to look up for me.
Pm sent. |
sygazelle11366.50 Spacecoast151.00 |
01-03-2018, 03:53 PM | #9 | |
Rep 42
I live in Edinboro PA and work in Erie PA, leading nation with 92” of snow so far. |
01-03-2018, 03:55 PM | #10 | |
Rep 42
I used e-brake to stop car then released e-brake and car crept forward at idle with foot on brake. |
01-03-2018, 04:03 PM | #11 | |
Rep 42
I went back home, turned off car and locked it. Reentered and started to drive to work and the issues have not presented again. Thank you all for your input. I am sorry I had to use so many “I think” comments. It was 5am and the situation took me by surprise so the situation is not crystal clear. Just lucky it happen where it did at the time it did or the car could have been “R” again. |
01-03-2018, 05:32 PM | #12 |
Rep 295
Drives: 2016 340i X Drive
I would have the car checked out at a shop before using it again. You don't want to be trying to stop at an intersection without any brakes.
01-03-2018, 06:13 PM | #13 |
Rep 641
01-04-2018, 10:01 AM | #14 |
Rep 327
Check brake fluid, it sounds like someone cut your lines.
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
01-04-2018, 10:29 AM | #15 |
Rep 2,118
01-04-2018, 01:33 PM | #16 |
Rep 1,572
If you are still under warranty, have your BMW service department check it out. That type of failure may have tripped an error code and stored it, they can pull or if you have a code reader, you can check yourself.
01-05-2018, 03:59 PM | #17 |
¯\_(ツ)_/¯
537
Rep 1,000
pump the brakes with the car off, does the pedal get stiff?
01-05-2018, 06:52 PM | #18 |
Dü Werke
420
Rep 87
I recall hearing of a fault similar to this (reference: https://www.autoblog.com/2013/09/28/...-brake-recall/)
Might want to mention this when you discuss with your local dealership. |
01-08-2018, 01:22 AM | #20 |
Rep 27
ABS in addition to not stopping a car on ice by design has trouble with snow and gravel.
The ABS light would illuminate and then go off. The fact that normal braking resumed later leads me to believe their was no malfunction of the braking system. Just a slick surface that ABS allows the wheels to keep tuning on. If you used your hand brake you were probably locking the brakes allowing you to stop. If the fluid level was low the brake light would be on and stay on. |
01-08-2018, 02:38 AM | #21 | |
Rep 103
hopefully nothing major is wrong with your brakes and it's due to the cold weather. |
01-08-2018, 04:30 AM | #22 | |
Rep 15,858
Did you pump the brakes during the incident? Solid, soft, etc. If you were getting ABS feedback, it does appear it was the surface conditions that were suspect. I came down my lane too fast the other day, had turned to ice while I was out. ABS pumped away as I tried to brake. Certainly feels like the brakes have failed, during something like that. Question I have is about the R title. Do you know the full history? If there is a problem, could it be related to that in any way? |
