BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Bluespark Tuning Box Review and Tech info
      10-17-2017, 02:39 AM   #265
YR430D
YR430D's Avatar
46
Drives: BMW 430D
Anyone tried the Mosslemann solution? They don’t quote any figures on their website?
      10-17-2017, 03:36 AM   #266
Smee
Smee's Avatar
505
Drives: BMW M4 F83
do you mean the new iTronic. no but i was very interested. sounds like a good bit of kit not sure how it works though
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit
      11-22-2017, 02:26 PM   #267
fabkat
Drives: F31 335D
Managed to pickup a bluespark pro + boost on an auction site and got it reprogrammed, anyone running this on a 325d? wondering what best settings are.
      11-22-2017, 03:57 PM   #268
KCH1984
Drives: Tesla Model Y LR
Have a look on Babybmw - few people running these on their 125d's (assuming this is the same engine as yours).
Seems the 25d suffers the same fuel cut issues as described in this thread on the 35d motor (wonder if something to do with the twin turbo setup) so you may want to try a conservative setting like C6 or D7 to begin with.
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
      11-23-2017, 01:06 PM   #269
fabkat
Drives: F31 335D
Good shout, forgot about that site Have it on C6 and defo notice a difference.
      01-19-2018, 06:55 AM   #270
PLuKE
Drives: n/a
I have just fitted my Bluespark CR1 Tech box onto my F31 330d so there cheapsest one via there eBay shop, £89.
Fitted the box on MAP1 on POSITION 5. Car feels better, they state that MAP1 is low/midrange power, with economy.
If I change it to MAP2 then that states maximum power higher revs, but will I have no lower down grunt and then just all the power in the upper rev range?
Any advice?
Thanks
Luke
      01-19-2018, 09:52 AM   #271
JLR1969
Drives: Kubota GR1600
Any advice?
Thanks
Luke
Not sure how the box is set up but when I had the BS Pro I had it on E7
      01-19-2018, 11:39 AM   #272
PLuKE
Drives: n/a
It has two settings MAP 1 and MAP 2
Then fine tune it from 1-5
I have it on maximum power at higher revs, with this setting, I am guessing there will be no extra power low/midrange revs now? It feels quick in all of the rev range on my 330d, more of a quick after 3000rpm.
Some graphs I have seen, on the BS Pro etc with it turned to maximum, that power has increased in all of the rev range,
Not just the upper.
Luke
      01-19-2018, 12:01 PM   #273
JLR1969
Not just the upper.
Luke
No idea then mate.
Ultimately you should just get a remap and get it done properly, it will save you money in the long term.
      01-19-2018, 12:14 PM   #274
PLuKE
Drives: n/a
No idea then mate.
For £80-90 you can’t complain, the car feels better. I think I will have to have a play around with the settings and see.
I was looking for an answer, instead of me changing the settings and then testing it out.
Thanks
Luke
      01-19-2018, 01:23 PM   #275
KCH1984
Thanks
Luke
I think teaston has the CR tech box, albeit on the 35d. His settings might be a good start. On the Pro box I think we all ended up on E7 in the end (whether 30d or 35d) so there likely will be some comparability. End of the day though there will be some personal preference involved. Personally I like low down shove, whereas other prefer to ring it out!
      01-19-2018, 01:44 PM   #276
JLR1969
Thanks
Luke
What I mean is once you start with engine tuning boxes etc you slowly progress to other options.
I went with a BS box then DTUK box then a remap.
A £90 tuning box is not very reassuring on a £15k engine.
The CR boxes are about as basic as you can get.
      01-19-2018, 01:52 PM   #277
PLuKE
Drives: n/a
I will take a look/ask the member.
Yea mines the basic CR Tech, I had the setting upped alittle over the default, now I have it on the maximum setting.
I like the lower/midrange grunt, like overtaking. There isn’t as much info on these boxe, compares to there upper end models.
I don’t want to add power “only” the upper rev range and add nothing lower down, as daily driving isn’t full throttle to the redline.
Thanks for your input!
Luke
      01-19-2018, 01:56 PM   #278
teaston
Drives: X3 M40d
Luke
On the CR tech the first 3 settings are for low end to mid range torque, setting 4 & 5 are for top end power.
I have mine on 3 (when it's fitted) as who can use top end power on public roads.
KCH1984947.00
      01-19-2018, 03:48 PM   #279
PLuKE
Drives: n/a
That’s great.
So I have mine on MAP2 and position 5. So if I have MAP2 and location 3, that should give me the maximum power in the midrange?
Is that how yours is currently setup?
Luke
      01-19-2018, 04:08 PM   #280
teaston
Drives: X3 M40d
That’s great.
Luke
Mine just has the 5 positions, no map1 & 2:
      01-19-2018, 04:33 PM   #281
Hooded
England
1669
Drives: F30 330d M-Sport
Quite
      01-19-2018, 04:52 PM   #282
PLuKE
Drives: n/a
Oh, yours is different.
Mine is like this?
      01-19-2018, 04:53 PM   #283
teaston
Drives: X3 M40d
Mine is like this?
Is yours a CR Tech 2?
      01-19-2018, 05:06 PM   #284
PLuKE
Drives: n/a
Mines a CR Tech 1, via the eBay shop.
Mines different, as the Pro+ etc has C,D and E and then a fine tune setting.
Looking for the best setting, I guess it’s trail and error and personal preference.
Luke
      01-19-2018, 06:13 PM   #285
teaston
Drives: X3 M40d
Luke
Oh I see, they told me the CR tech 1 wasn’t suitable for the 335d.
So what colour dot does yours have on the box?
      01-19-2018, 06:23 PM   #286
PLuKE
Drives: n/a
Mine has the red dot on the box.
My confusion here is, they list Map 1 and Map 2 twice as you can see.
So unsure, does moving the jumper from 1 to 2 make a difference? Or does the fine tuning jumpers make the difference.
I don’t want to mess with it to much, and then cause a problem.
Luke
