BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Remote Turn On HELP!!!!
Studio RSR
      05-07-2016, 09:39 PM   #1
ClevelandBeemer
ClevelandBeemer's Avatar
94
Drives: 2013 BMW 335i M-Sport
2021 BMW X5 45e  [0.00]
2013 335i  [0.00]
2015 BMW S1000R  [0.00]
I have a LC2i that I'm looking for a remote turn on source. I have the HK system and my LC2i is located next to the factory amp. It was my understanding that you can tap the 12 accessory outlet in the trunk. I've attempted to tap with zero success!?!
Any suggestions??
      05-08-2016, 03:18 AM   #2
carlr
carlr's Avatar
99
Drives: 2022 G22 M440i
Ehh - you don't need a remote turn on for the LC2i - it generates a turn on signal based on the high level inputs? You would use the remote turn on from LC2i to patch into your aftermarket amp. The LC2i itself only requires +12v and ground - no turn on.
      05-08-2016, 10:06 PM   #3
ClevelandBeemer
94
2013 335i  [0.00]
Due to the HK being a class D amp it will not turn on by sensing factory amp signal.
I appreciate the feedback though. I figured out the problem and now have a 100% functional system.
      05-09-2016, 01:07 AM   #4
TMR
TMR's Avatar
Drives: M3
What did you use for turn on?
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/
SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/
SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/
      05-09-2016, 06:07 AM   #5
carlr
carlr's Avatar
99
Apologies - i missed the small detail that you had HK
      05-09-2016, 08:33 PM   #6
ClevelandBeemer
94
2013 335i  [0.00]
The 12v accessory outlet above the factory amp.
      05-10-2016, 11:15 AM   #7
carmo
Drives: 2014 320i xdrive
And if that doesn't work then you can use that "add a fuse" gadget that piggy backs on an existing trunk fuse slot. Not sure how safe this is but I am told that most of those fuses turn off after 5 minutes of shutting down the car.
      10-30-2016, 03:33 PM   #8
law2004
Drives: 2015 435i
Does that 12v accessory outlet turn off after 5 minutes?
I did a subwoofer install with the HK system as well.
      10-30-2016, 06:52 PM   #9
ClevelandBeemer
94
2013 335i  [0.00]
It's more like 15 min but yes.
      10-30-2016, 07:00 PM   #10
law2004
Drives: 2015 435i
Ok cool. Got it all plugged in.
Thank you
