06-22-2018, 10:10 AM | #1 |
Rep 2
sunroof odor
I have a 2018 330i. There is a horrible odor from the sunroof when you have open. The smell starts at about 40 mph. Have owned 3 bmw's with sunroof and never had this smell. The dealer has changed the lubricant and smell still exists.
06-22-2018, 12:58 PM | #3 |
Rep 1,615
Definitely sounds like something is rotting in there but I also recall someone saying the lube they use in there stinks...maybe it's that?
Used mine this morning (0-62mph) and didn't detect any odd smells...
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
06-22-2018, 01:18 PM | #4 |
Rep 8,942
Seems like water is getting in there
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
06-22-2018, 03:02 PM | #5 |
Big Beaver Smile
2101
Rep 3,791
I had that exact same thing in both my 2014 528 and my 2016 435. I’ve never had that in any car before. They replaced the lube in both cars sunroofs and its 99.99% better. That stink just gets right in your nose.
Good luck!
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
06-22-2018, 06:53 PM | #6 |
Rep 1,487
Drives: 2108 X3 xDrive30i
06-22-2018, 07:06 PM | #7 |
Rep 8,942
Not if it got under your headliner somehow and started to mildew and rot although I suspect you'd see staining now that I think about it. Maybe not though.
2022 Macan S
06-22-2018, 07:36 PM | #8 |
Rep 1,487
06-22-2018, 09:14 PM | #9 |
¯\_(ツ)_/¯
537
Rep 1,000
makes me think wtf were they using? Truffle Butter?
06-23-2018, 08:07 AM | #10 | |
Big Beaver Smile
2101
Rep 3,791
12-16-2018, 07:30 AM | #11 |
Rep 4
I have a horrible smell, it's coming from the wind deflector mesh when wet, best described as a cat wee smell. After car has been sat for a while and it's been raining the mesh is always wet. And the smell seeps into the car. So run your fingers on it when open and it stinks. Spoke to the dealer and they just had no answer how to solve it, so I dry it and spray frebreeze on the mesh, this solves the problem for a while.
12-16-2018, 07:59 AM | #12 |
Rep 5,993
Must be a leak somewhere or clogged drain tubes in the moonroof rain gutter system. There should not be standing water which would cause mold and mildew. Might be more of an issue in states with more rain, snow and ice.
12-16-2018, 08:48 AM | #13 | |
Rep 1,594
Drives: '23 760ix; '23 X3; '23 MB wgn
Of course, the short term approach is not to open the sunroof.
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '23 MB E Wagon Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler. |
12-16-2018, 04:45 PM | #14 | ||
Rep 5,993
12-16-2018, 07:37 PM | #15 |
Rep 153
Drives: 2014 428xi Sport Line
I think you are smelling car odor as air is drawn through the car. To explain, the sunroof when open creates a draw or vacuum of air through the car. The air picks up odor as it moves through the car. With the windows up and the climate system off open the sun roof and put your hand over the window/mirror switch panel. You will feel air against your hand. That air is being drawn in from somewhere carrying the offensive odor into the cabin. After a while the smell goes away. At least this is what I think is happening.
12-16-2018, 11:46 PM | #16 |
Rep 1,827
You could also try pulling the cabin air filter and see if it's clean. Give it a whiff to see if maybe that's the source?
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
12-17-2018, 12:11 PM | #17 |
Rep 2,197
I recall some posts about a smell that was traced back to the lubricant used on the sunroof rails.
12-17-2018, 07:33 PM | #18 | |
Not stock
474
Rep 617
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
12-17-2018, 07:42 PM | #19 |
Rep 17
I have a 2016 GC and the same smell is there since it was new (and still after 3 years). I live in the dessert and technically no rain could have gotten into the mechanism or somehow under the roof. Consequently, my take is that the lube smells like pee....
12-19-2018, 12:17 AM | #20 |
Rep 1,827
This brings up a question, my car is now over 5 years old with 102k+ on the odometer. Is re-greasing the sunroof needed as maintenance at any point? Apparently, using oem might not be the most desirable.
