12-28-2017, 06:38 PM | #1 |
Rep 216
Tire rotation questions
Just wondering what you guys think the pattern should be.
Vehicle: 2017 340i m sport Summer is staggered setup 20' 405m wheels non directional Winter is non staggered 18' non directional Curious more so for my staggered setup, should I rotate side to side or just leave them.
2017 340i M Performance Edition: Fashion Grey, MPPSK, M performance front splitter, rear diffuser, side sills, black grille, CF spoiler, 405M 20s, 8AT, full Marino interior and dash, adaptive suspension
12-28-2017, 07:53 PM | #3 |
Rep 2,196
For decades BMW has not advocated tire rotation. The tires "take a set" on the corner they are mounted on & moving them can upset the wear pattern. A quick search found:
http://www.1addicts.com/forums/showthread.php?t=253700 https://www.cartalk.com/content/owne...-my-bmw-i-says
01-02-2018, 02:33 PM | #5 |
Rep 1,572
From my 2013 F30 (335) 3 Series Owners manual:
"Rotating wheels between axles The manufacturer of your vehicle advises against swapping wheels between the front and rear axles. This can impair the handling characteristics." |
01-02-2018, 03:02 PM | #6 |
Rep 5,456
As long as the set up is square:
Cross to the front, straight back. |
MacklinUSOB518.00 |
01-02-2018, 03:26 PM | #7 | |
Rep 891
Michelin Owners Manual/Warranty Terms: "In order to maintain the treadwear warranty on your tires, the tires must be rotated every 6,000 to 8,000 miles (10,000 -12,000 km), or as recommended by the vehicle manufacturer, whichever rotation period is less. Failure to rotate the tires as provided herein voids the treadwear warranty.." Continental Total Confidence Plan Terms: "Tire(s) that have not been rotated at least every 6,000 to 8,000 miles (10–13,000 Kilometers), as evidenced by a completed Rotation Schedule, are excluded from this coverage."
01-02-2018, 04:11 PM | #9 | |
Rep 216
Much appreciated.
01-02-2018, 05:14 PM | #10 | |
Rep 5,456
Not rotating your tires with a square set up is simply a dumb idea... regardless of who disagrees. In the past, I have swapped wheels side to side on staggered set up but If you are only putting five or eight thousand on per summer then maybe not as necessary. I will be rotating my DSW06's every 5k with oil service. I will also be riding these for 60k miles. Choosing to not rotate and wear a thousand dollar set of tires out prematurely is just silly! |
MacklinUSOB518.00 |
01-02-2018, 06:01 PM | #11 | ||
Rep 216
01-03-2018, 07:01 AM | #12 | |
Cheapskate
4447
Rep 4,993
The only thing I can think of is a directional tire that specifies which shoulder should be on the outside, but I can't think of any tires that are designed that way off the top of my head. And i'm almost positive no OEM tires are directional. |
01-03-2018, 02:14 PM | #14 |
Rep 1,572
BMW only states not advised to rotation front to rear, rear to front. They dont address side to side. I just sent a msg to BMW USA about their statement and our discussion. Will pass on what I get as a response- if any
01-03-2018, 10:56 PM | #15 |
Rep 216
Great, I'm interested to hear what they say
01-03-2018, 11:00 PM | #16 |
¯\_(ツ)_/¯
537
Rep 1,000
Here you go
if you have xdrive i'd do the x pattern on the non-staggered wheels, for staggered Go left to right and right to left |
01-05-2018, 01:16 PM | #17 |
Rep 1,572
Surprizingly, I received a response from BMWNA this morning. See below:
(Quote) Thank you for writing to BMW of North America, LLC regarding tire rotation for your 2013 BMW 335i Sedan. We appreciate your inquiry. Different wear patterns can occur on the front and rear axles depending on individual driving conditions. The tires can be rotated between the axles to achieve even wear. After rotating, the tire pressure should be checked and corrected if needed. Rotating the tires is not an option on vehicles with different tire sizes or rim sizes on the front and rear axles. Should you require additional information, the service team at your authorized BMW center has the expertise and knowledge to further assist you. For your reference, a list of our authorized BMW centers can be found on www.bmwusa.com; simply select the “Find a Dealer” link located at the bottom of the page. (Unquote) |
MacklinUSOB518.00 ishowerinjager111.00 |
01-05-2018, 02:54 PM | #18 | |
Rep 891
01-07-2018, 05:43 PM | #19 |
Cheapskate
4447
Rep 4,993
The problem they are completely skipping is tires will wear unevenly from side to side as well. You don't only rotate tires front to back.
Do what you want, but it's not rocket science. BMW will also tell you there is only one brand of oil, coolant, probably even gas if Shell tossed them a few bucks. There is a lot of engineering and development behind our cars but at the end of the day, it's still just a car. All the rules of physics still apply. |
