12-28-2017, 02:34 PM | #1 |
Rep 423
Apex EC-7 fitment question
Car: 2014 335 xdrive msport/w big brakes
Current wheels: 18" 400m staggered, 19" 403m staggered New wheels: Apex EC-7: 18x8.5 ET 35 (all 4) Questions: 1.) will these clear the big blue msport brakes? 2.) what size tire should I run all around for summer driving? Let me know. Thanks |
12-28-2017, 04:41 PM | #2 | |
Rep 4,324
tire size 255/40/18 or 245/40/18. michelin PS4S or PSS. continental extremecontact sport, pirelli PZ4 |
ProperBimmer231.00 |
12-28-2017, 05:58 PM | #3 | ||
Rep 423
12-29-2017, 12:23 AM | #4 |
Rep 4,324
oem diameter is 26". 245/45/18 is 26.7". could you do it? yes. i'd just stick to 255/40/18, tho.
http://f30.bimmerpost.com/forums/sho...40%2F18+square Last edited by alohasurftoad; 12-29-2017 at 12:37 AM.. |
12-29-2017, 12:40 AM | #5 |
Rep 797
I've spent the past few weeks trying to spec wheels..
18x8.5 et34-38 with 255/40/18 or 245/40/18 is 'the' setup. Your choice if you want the slight bulge or square sidewall, and extra grip or less weight/resistance. The 255s are the exact same as the OEM height 225/45/18 so if you run those in the winter it will look exactly the same. 245s are 7mm smaller.. Either in 45 sidewall would look monster truck ish. Good call on the 18s. https://tiresize.com/calculator/ https://tiresize.com/wheel-offset-calculator/ |
01-10-2018, 11:08 AM | #6 | |
Rep 423
01-10-2018, 11:46 AM | #7 |
Rep 4,324
[QUOTE=ProperBimmer;22633119]Thank you. If I ran 19x8.5 all around would I still do 35et? And what tire size would you recommend?[/QUOTE
+35 is safe. 235/40/19, 26.4" diameter, 10mm stretch on 8.5", little narrow on the tread for me 245/35/19, 25.8", perfect fit on 8.5" 255/35/19, 26"=oem, 10mm slight bulge on 8.5", hardly noticeable personally i'd do 255 square but any of these would be fine this is what 19x8.5" +35 w/255/35/19's square looks like, thanks @BIMMERGUY91 http://f30.bimmerpost.com/forums/sho...ht=BIMMERGUY91 |
01-27-2018, 03:48 PM | #8 | |
Rep 423
[QUOTE=alohasurftoad;22633328]
