09-22-2014, 11:24 AM | #1 | |||
Rep 4
Upgrading from HU_ENTRY no BT to HU_ENTRY with BT+USB
Situation:
The F30 which I bought brand new did not come with either USB or Bluetooth. It was apparently manufactured with a L7 ENTRY unit (which maps to HU_ENTRY in coding terminology) with no bluetooth of USB capability. Target: To install Bluetooth telephone operation and USB audio Chosen Pathway: To Install a donor L7_ENTRY with USB and bluetooth telephone capability and do the VO coding (6NH) to enable the functionality. Assumptions:
Tools:
Thanks to: Shawnsheridan and everyone else's effort who have brought these methods available to us. Conclusion : (I have brought it to the front to assist people who might not be interested in the detail below. It appears the HU_ENTRY needs a FSC code to enable USB and Bluetooth. AppID 129(0x81) - USB music, AppID 130(0x82) - Bluetooth handfree. Thus if the HU_ENTRY unit (L7_entry) is coming from a donor car, it would not work in the target car without the above codes. I have no idea how one would obtain these codes. TARGET (my) Vehicle Order before any modification: 169,205,216,240,249,258,2FH,423,428,497,4CG,507,52 0,548,699,825,850,853,861,880,8KK,8S3,8TM,8TN,925, 9AA (note: I cannot see a Head unit entry in this VO, but this is how it was originally) Journey: Introducing the new unit The donor L7_ENTRY was first introduced by plugging in the following in this order, 2 x diversity Antennas, Rosenberger APIX connector, Quadlock connector. At this point no coding had taken place. The unit booted up and showed additional menus for Telephone, Contacts and BMW services (or such) which I did not previously have in my head unit. When I navigated in to the Bluetooth section I could see the Donor units existing bluetooth pairings. At this point, pleasantly surprised that I didn’t need any coding, I proceeded to discover and add my phone in to the Head unit through the normal process. It synced contacts, call logs to the vehicle. At this point I tried to make a call through iDrive, and it worked (i.e. I could hear the dialled party). Losing Bluetooth As I continued to play with the system I noticed that data profile (next to the icon representing Hands Free Profile) was inactive. The tweaker in me immediately proceeded to enable it. After which, I went in to the BMW Services (or similarly named) main menu (between contacts and vehicle information options if memory serves) to see these services in action. Within this menu it had an option to update the service (or similar idea). It was promptly clicked, in return a screen indicating that I was trying to connect popped up. And was stuck at trying to connect. Though the iDrive system was fully responsive. Trying to go back in to the bluetooth menu showed a spinning circle and nothing else. <image attached>. After this point the bluetooth menu showing the devices connected or disconnected has not appeared, though every other aspect of the iDrive system is operational. Searching using my phone or laptop does not find the previously operational bluetooth client either. VO coding At this point I assumed that the ECUs have synced and finally noticed that this L7_ENTRY was not part of the original VO, thus shutting off some of its capability brought in from the donor vehicle. E-sys was promptly fired up. Then noticed that CAFD was not showing in the HU_ENTRY ECU. Initializing connection between CAR <-> E-sys
Used the following method to insert CAFD. Quote:
VIN mismatch In Comfort mode -> FSC Status I noticed that the VIN programmed in HU_ENTRY was still the DONOR vehicles VIN. Code:
--> Read the state from "2" ECU(s) <-- EPS[DiagAddress=48(0x30)] WBA3D32040F*TARGET* RootCertStatus not available SigSCertStatus not available SWSigStatus accepted SWTApplications ---------- AppID 131(0x83) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus accepted FSCCertStatus not available HU_ENTRY[DiagAddress=99(0x63)] WBA3E12060F*DONOR* RootCertStatus accepted SigSCertStatus accepted SWSigStatus accepted SWTApplications ---------- AppID 129(0x81) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus rejected FSCCertStatus accepted ---------- AppID 130(0x82) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus rejected FSCCertStatus accepted ---------- AppID 143(0x8F) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 144(0x90) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 111(0x6F) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 27(0x1B) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted The next step was to see if changing the VIN to my TARGET VIN would solve the problem. I used the following process to Flash the firmware of the HU_ENTRY and thus changing the VIN. Firmware Flashing Process. Quote:
following the completion I got the following LOG for the flashing process Code:
TAL execution started. ExecutionID=2014/09/21-14:32:27.553 TAL-Execution finished with status: "Finished". [C207] TAL execution finished. Duration: "27min 34s". [C206] MSM update: Read current SVT. [C194] MSM update started. [C215] MSM update finished with error. [C217] Error in MSM Update: [] - [Exception - MSM - 10] Errors: TSL distribution failed due to an error: FsCSM with diagnostic address 0x63 reports error: error code: 'ERC_MSM_NO_RESPONSE_FROM_CSM', specific error code: 'empty' (F30 key exchange); FsCSM with diagnostic address 0x63 reports error: unknown error (F40 fingerprint exchange) Error during MSM update. [C214] Errors: TSL distribution failed due to an error: FsCSM with diagnostic address 0x63 reports error: error code: 'ERC_MSM_NO_RESPONSE_FROM_CSM', specific error code: 'empty' (F30 key exchange); FsCSM with diagnostic address 0x63 reports error: unknown error (F40 fingerprint exchange) [1352] VCM Update: Write FA to VCM. [C188] VCM Update: Write FP to VCM. [C190] VCM Update: Write integration levels to VCM. [C186] VCM Update: Read current SVT. [C191] VCM Update: Check current SVT with TAL. [C192] VCM Update: Write target SVT. [C193] VCM Update: Write FA to backup. [C189] VCM Update: Write integration levels to backup. [C187] VCM Update: finished. [C195] After Flashing the following FSC status was shown. Note that the VIN of the HU_ENTRY ECU was showing the VIN of the TARGET (my) vehicle. Code:
--> Read the state from "2" ECU(s) <-- EPS[DiagAddress=48(0x30)] WBA3D32040F*TARGET* RootCertStatus not available SigSCertStatus not available SWSigStatus accepted SWTApplications ---------- AppID 131(0x83) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus accepted FSCCertStatus not available HU_ENTRY[DiagAddress=99(0x63)] WBA3D32040F*TARGET* RootCertStatus accepted SigSCertStatus accepted SWSigStatus accepted SWTApplications ---------- AppID 129(0x81) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus rejected FSCCertStatus accepted ---------- AppID 130(0x82) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus rejected FSCCertStatus accepted ---------- AppID 143(0x8F) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 144(0x90) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 111(0x6F) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 27(0x1B) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted Then I proceeded to VO code the car following the above outlined process. Still, Trying to go back in to the bluetooth menu showed a spinning circle and nothing else. <see image above>. Analysis: It appears that AppID 129 and 130 are rejecting the FSC codes now due to the change in the VIN. I am assuming that this could be a reason for Bluetooth not working, if it is considered an APP in the system. (I found someone else eluding to this as well link, link " AppID 129(0x81) should be USB music, and AppID 130(0x82) should be Bluetooth handfree. " AppID 129(0x81) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus rejected FSCCertStatus accepted ---------- AppID 130(0x82) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus rejected FSCCertStatus accepted FDL Coding At this point I tried to go disable anything pertaining to Connected Drive, BMW Live or similar. Coded the updated FDL. Still, Trying to go back in to the bluetooth menu showed a spinning circle and nothing else. <see image above>. So Guys at the end of this I am out of explanations or ideas. I wouldn’t have bothered anyone normally, especially guys like shawn who seems to be quite busy with requests by the looks of it. But I am all out, looking for inspiration. Thanks, |
09-22-2014, 07:23 PM | #2 |
Rep 41,044
All your assumptions are correct. Your dilemma is that the only way you can use the donor FSC Codes is to keep the Head Unit VIN as the donor VIN as if your change it to match the car VIN the FSC Codes will be rejected. The problem with this is that since the Head Unit and car have different VIN's, Activation will still fail.
This is why all Head Unit Retrofits have either OEM FSC Codes ordered form BMW AG matching the car's VIN or they use Donor FSC Codes / VIN and a CAN Filter / Activation Module to fool the car into thinking the Head Unit VIN matches the car's VIN.
09-22-2014, 08:02 PM | #3 |
Rep 4
Thanks. this was a fear.
is it possible to get FSC codes issued for my VIN at this point. ? a search on the forum shows a mention of Chang for such things. would I be able to get his or any other contacts email? interestingly the code generators used for maps seem to be having a private key, even though the output code size is smaller for iDrive entry. |
09-23-2014, 10:01 PM | #5 |
Rep 41,044
All FSC Codes with the exception of Map FSC Codes must be issued by BMW AG, and signed with their Private Encryption Key. Any seller, be it Chang or Dealer must order them form BMW, so you might as well start with your dealer, and see if they can order them.
09-24-2014, 08:43 AM | #6 |
Rep 1,980
Drives: 2020 G20 320i M Sport
This is new to me. It's actually possible to have an F30 with no 6NH????
06-06-2016, 03:12 AM | #8 |
Rep 8
Hi! I also own a F34_03/2013 with HU_ENTRY without BT+USB only AUX
Is it possible to use an emulator (Maybe the same one that is used for NBT units) to retrofit an HU_ENTRY with BT? will it work? Same as garathf30 i only have code 698 (Area-Code 2 for DVD Regional) and 6WA (Extended Instrument Cluster). No Head Unit entries. If things work with an emulator which VO Codes do i have to insert for HU_ENTRY with BT+USB? And a last one. Can i retrofit an NBT Unit? Sorry for my English! Thank You! Last edited by ilotas; 06-06-2016 at 11:26 AM.. |
10-20-2020, 02:53 AM | #14 |
Rep 21
Do you have a simple solution for this problem ?
Can an emulator on the quadlock connector fix this problem ? If so what type of emulator ? Are there any FSC codes now ? |
