BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > OTA Map Updates issue?
      06-22-2017, 11:37 AM   #1
Golo2016
Golo2016's Avatar
53
Drives: BMW 540i Xdrive
Hi to all,
I tried to search around, but couldn't find an updated thread.
I purchased a CPO 2016 340i back in march with 7k miles on it. I'm under the impression that I have OTA updates as I can see it that it has the 2016 when I check in the IDrive. I've change the locations (on the ConnectedDrive website) for the update to 12(Virginia,DC and other,) to 13(Maryland, and up,) It's June 22nd and I still haven't received any OTAs for 2017.
Does anyone else have had this issue with the Maps not updating OTA? Thanks in advance.
      06-22-2017, 06:33 PM   #2
robchimo
Drives: 2016 328xi
I'm having the same issue. 2016 328 with pro nav. Current version of maps is from 2015. I have connected drive active. Is there a way to force the map to download?
      06-22-2017, 09:50 PM   #3
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Download maps, plug into USB, let update.
      06-23-2017, 09:55 AM   #4
Golo2016
Golo2016's Avatar
53
Can I do that having OTA updates? If so, can you point in the right direction? Thanks in advance.
      06-23-2017, 01:47 PM   #5
Almaretto
Almaretto's Avatar
2374
Yes. USB uploads all of NA. OTA just updates designated region (1 of 13).
      06-23-2017, 09:51 PM   #6
vp
Drives: MY18 430GC
How does one "download" maps onto USB in the US for nbt evo?
      06-24-2017, 01:11 AM   #7
Almaretto
Almaretto's Avatar
2374
Join enthusiast websites and make contacts where you can download for free. Files are just downloaded and extracted onto 32+ GB, FAT32 formatted flash drive.
      06-29-2017, 06:15 PM   #8
Golo2016
Golo2016's Avatar
53
I just finally got an OTA update. It was fairly quick and just came out of the blue. Now I have 2016-2, i'm kinda bumped out as we're in July 2017, question, will I eventually get an OTA update for the 2017s maps? I'm kinda confused and don't know if I should spend the money to get an update when, essentially, I have free OTAs.
      06-29-2017, 06:28 PM   #9
Almaretto
Almaretto's Avatar
2374
Your guess is as good as mine whether and when you will get 2017.
  • I have seen 2017-1 natively installed on (March) systems and available for download.
  • I have also seen 2016-4 and other OTA.
  • I only have a list of latest complete system updates. I know what constitutes the 13 regions, but not sure how regional updates are pushed (ie does one region get 2016-2 & another 2016-4, etc?).
      06-29-2017, 09:44 PM   #10
Golo2016
Golo2016's Avatar
53
Thanks for the reply, can I download the 2017 maps into an usb drive and install it into the car without a FSC code? I saw in other thread something in those lines...
      06-29-2017, 09:45 PM   #11
Almaretto
Almaretto's Avatar
2374
Yes. Depending on year of car, you will have 2-4 years of FSC's pre-loaded.
      06-29-2017, 09:54 PM   #12
Golo2016
Golo2016's Avatar
53
Mine is a 2016 340, will it work on this one? Where I can get the maps? Sorry for all the questions.
      06-29-2017, 09:57 PM   #13
Almaretto
Almaretto's Avatar
2374
My 2016's (F010/F015) got updated from Next 2015-2 to 2017-2 (which each step in between) without ever entered FSC. That was not the case for My '13 BMW's.
If you are getting OTA (or should), I would assume preloaded as well. But, only way to know for sure is to pull info from car.
I get most of my stuff from Cartech.
      06-29-2017, 10:02 PM   #14
Golo2016
Golo2016's Avatar
53
Ok, I saw a place with the maps, I will get a flash drive tomorrow and try it, will post back the findings. Thanks!
      06-30-2017, 04:05 PM   #15
Golo2016
Golo2016's Avatar
53
I purchased the flash drive, downloaded what I believe is the North America 2017, I downloaded it to the drive then proceeded to inserted it into the car. The car recognized that there's something in the usb port, but nothing else, the car didn't even budged. Don't know what i'm doing wrong.
      06-30-2017, 04:56 PM   #16
Almaretto
Almaretto's Avatar
2374
Maps are region (eg North America, Europe, etc) & head unit (eg Next for NBT, Evo for NBT2, etc) specific.
Contents (numbered folders plus configuration files) also must be extracted and placed in root directory of fat32 formatted flash drive. If using Mac, you must use secondary program to delete hidden directories/files.
Once done right, plugging in will result in popup prompt on CID that newer version recognized and ask if you wish to update.
      06-30-2017, 07:44 PM   #17
Golo2016
Golo2016's Avatar
53
I give up, I've downloaded the maps, waited it for it to download and then transfer it to the drive to no avail. I'm just going to roll with the OTA updates.
      07-01-2017, 12:08 AM   #18
Almaretto
Almaretto's Avatar
2374
That is an option.
      11-04-2018, 12:30 PM   #19
Pequin
Pequin's Avatar
Drives: Enthusiastically
OTA updates - Apparently not available
After a few weeks of frustration, calls to connected drive (not a clue) Discussion with my dealer, I finally found the page within the connected drive store, it appears that the OTA updates are not available in the UK, or at least I couldn't select the UK one, all other regions were available
