10-13-2018, 12:38 PM | #1 |
Rep 87
6WB problem
hi all
friend of mine got 6wb (second hand); his car was badly coded to start with. I fixed (so I think) most of errors ie VO still said 6wa. He has famous RED DOT in cluster. which i am struggling to get rid off. I checked fahrgestell_nr_rda in KOMBI and it has his cars vin inside; picture in below. I did however run vin report from esys and I got below which i think is the reason why red dot is there in first place; see below I would believe that reason for three VINs in that is; swapped engine; swapped EDC and obviously cluster. appreciate your help |
10-13-2018, 06:17 PM | #2 |
Rep 765
10-15-2018, 10:09 PM | #5 |
Rep 10,473
10-30-2018, 03:51 AM | #7 |
Rep 29
Hi all,
i'm having trouble with my 6wb retrofit. i've purchased a virginized 6wb cluster it arrives and 2 different coders have found problem whlie coding with the below error. we finally decided to flash it but still with the enet cable connected to the can2 we had another error after that the red dot appears ( because there is no vin no anymore to the kombi) the coder says that i still need another cable that is a oabr to ethernet cable can you please support me here? thank you |
