BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Blown turbo on b58???
Studio RSR
      03-08-2019, 03:20 PM   #23
kriszty
kriszty's Avatar
329
Drives: B58 M240ix pureturbo800 dorch1
Originally Posted by B58togo View Post
8-10k; that’s nuts. If this happened to me out of warranty I’d go Pure Stage 2 for $2250 and pay a BMW Indy $1200 to install it.
total agree
      03-11-2019, 05:19 PM   #24
doodlebro
Drives: '17 X3 35i
Hope it works out for you OP, when I took my N55 in for a turbo failure I could not put the stock downpipe back on (stripped lower O2 hole). They told me at first that warranty would be honored, but 4 days later they pulled it away.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280'
      03-18-2019, 08:24 AM   #25
Stopsign32v
Drives: 2003 Mach 1
Don't they have to PROVE the modification caused the failure in order for them to void the warranty?
      03-18-2019, 08:33 AM   #26
Who's on first
Who's on first's Avatar
Drives: A-10C
Technically yes. But they can respond like this...
Dear BMW Owner,
We will get back to you in 30-45 days, while we compile our evidence. You should look into a rental in the meantime.
Once evidence is gathered, we will send your lawyer the information.
Talk to you soon,
BMWNA.
P.s. You should go ahead and get a lawyer.
      03-18-2019, 08:45 AM   #27
bmw22915
Drives: 440xi GC
Dear BMW Owner,
Talk to you soon,
BMWNA.
It's not that they voided the warranty, they gave me a very high risk option that could have been very costly. If the turbo work does not get warrantied, I would be responsible for ALL work on the car. Even the labor to just diagnose the issue.
I went to a different dealer for a second opinion and found out dealership number 2 has been approved to repair the car under warranty. The car does need a new turbo. They had an engineer visit and take a look at the car and he said a bearing went bad and caused the turbo to fail.
Parts are now on the way and hopefully I get the car back before the end of the week. The X3M loaner I've been driving is definitely growing on me haha.
      03-18-2019, 08:47 AM   #28
bmw22915
Drives: 440xi GC
Did they do any work prior to the four days and were you charged for it?
      03-18-2019, 08:48 AM   #29
Stopsign32v
Drives: 2003 Mach 1
Dear BMW Owner,
Talk to you soon,
BMWNA.
Fair enough, at this point though wouldn't they be responsible for ALL of your costs due to their lack of incorrect diagnostics? AKA they then pay for your rental, lawyer fees, and time/suffering? Seems if they want to stick you then they should pay for it.
      03-18-2019, 02:35 PM   #30
MassNerd
MassNerd's Avatar
Drives: 2019 M240i Coupe RWD
This is the 2nd time I've seen a turbo replacement cost quoted at $7K+.
That seems ridiculous and makes an extended warranty worth considering...
      03-18-2019, 02:45 PM   #31
Stopsign32v
Drives: 2003 Mach 1
Or turbo upgrade worth considering...
jalkster220.00
B58togo808.50
MassNerd171.00
MaximusJ303.00
      03-18-2019, 04:13 PM   #32
MassNerd
MassNerd's Avatar
      03-19-2019, 02:48 PM   #33
doodlebro
Drives: '17 X3 35i
They took apart the intercooler and charge pipes, as well as performed a leakdown & compression test on the first 3 cylinders. I knew going in that there would be a diagnostic fee of up to $1400 and that is what they tried to charge me. I talked it down to $800 due to how ridiculous the whole thing was.
Current mods
      04-30-2023, 11:16 PM   #34
Serb
Serb's Avatar
Drives: bmw 340i
hey guys, my stock turbo on my 2016 340i recently said bye bye and i’m stuck deciding what to do next. as of now it’s on mhd stage 2 on 93. current mods include upgraded open box air intake, vrsf charge pipe/ downpipe and new coils/plugs. i’ve also been having the issue of the car running too lean due to upgraded air mods and nothing done to the fuel system yet. I need suggestions on what turbo setup to replace the stock one with and also any supporting mods to go along with it. of course after these are all replaced it will be gettting a custom tune, not just a ots mhd tune… thanks for the help in advance
      05-01-2023, 04:15 AM   #35
F36Imani
F36 440i Gran coupe
F36Imani's Avatar
Drives: 440i Gran coupe F36
How many miles did you have? & You think it’s from the OTS tune or just bad luck? + did you have any error codes when running to lean or was it a hidden code etc ?
Do you think maybe if you had a stock air box and wasn’t running lean it would of kept the turbo safe?
Just wondering since now I’m scared I’m on BM3 stage 2 & have an mst type air intake but it’s inclosed lol..
Serb1.50
      05-01-2023, 04:57 AM   #36
DieselDuck
DieselDuck's Avatar
94
Drives: BMWB58
Use the stock airfilter system to start with, works fine on both stock and upgraded turbo and protects best against dirt/sand etc. Then the fact you were aware your car was running too lean is a bit questionable ? lol
      05-01-2023, 07:07 AM   #37
Serb
Serb's Avatar
Drives: bmw 340i
the car just hit 70k miles, bought it at around 64k and the only code that i’ve had come on was for the gas cap being too loose. i would assume it’s from being on a OTS tune instead of custom and accommodating for specific mods. my fault i know but im just looking for advice on how to rebuild now. what’s the best upgrades tueno setup? was looking into the new cast pure 800 maybe
      05-09-2023, 08:13 PM   #38
Serb
Serb's Avatar
Drives: bmw 340i
blew my stock 340i turbo and upon taking it off it looks like exhaust ports 4,5 and 6 are oil soaked but 1,2,3 are bone dry. anyone know this might be? the car runs too well for it to seem to be a mechanical issue
      05-10-2023, 11:58 AM   #39
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
The ots tunes as long as you're running what fuel the tune is for is 100% fine and your mods have nothing to do with anything. These cars have a wideband 02 sensor and it allows to computer to adjust for a preset air fuel ratio. Even the stock tune adjusts for the intake and downpipes etc. The idea that because you didn't have a custom tune done is by and large completely false..
Now when you get into large turbos you have issues with boost control sometimes and different throttle positions etc and will likely need a tune. Now for a stage 1 type it will run fine on a ots map etc.
You just had bad luck man.. it sucks. May as well grab a used oem from someone who's upgraded already or upgrade yourself. Good luck.
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      05-17-2023, 09:21 PM   #40
Brett530
Brett530's Avatar
208
Drives: '17 F30 340i
I guess this can be the failed turbo thread.
My 2017 340 with 33k miles has a bad turbo too. I've been tuned a long time, but just OTS maps, stage 2+. CG catted DP, Dorch 1, E40. Maybe 420-ish HP (never dyno'ed). Anyway, I have a DAW 2.5 on order - no reason to get a stock turbo at this point.
2017 F30 340i RWD // MG Flasher // xHP // CG DS-1 // ZTR ZMP ZCW ZLP
      04-23-2024, 07:42 PM   #41
f30Nate
f30Nate's Avatar
Drives: 340i Bmw
6466 turbo for gen 1 b58 is it blown?
      04-24-2024, 10:07 AM   #42
ZXMarine72
Drives: BMW M240i
Turbo Blown
F30Nate - Something that shouldn't have clearly went through that turbo. You can see the damage. I would not run that unless it get's a rebuild. Just my two cents though.
