      01-28-2013, 08:26 AM   #2355
shawnsheridan
shawnsheridan's Avatar
Originally Posted by XmX32 View Post
I can't believe i forgot to do that
thanks
      01-28-2013, 09:42 AM   #2356
Yobyot
Yobyot's Avatar
490
Drives: MY19 X3 M40i
BitTorrent transfers
Earlier, I suggested that we should use BitTorrent to share the E-Sys and PSdZData files. This should make it easier on shawnsheridan by lessening reliance on an ISP and should make transfers both more reliable and faster.
Attached to this post are four .torrent files representing the four sets of files I was given access to. You should download the files and remove the .pdf extension, then use them with a good BitTorrent client, either uTorrent or qBitTorrent.
I STRONGLY recommend that you use these torrents and DO NOT rely on the http download links you may get from other members. First, it's clumsy to download all the files individually and second I discovered that the http transfers would sometimes not transfer the whole file. It took days to get all the files downloaded correctly. (I have tested the .rars and .exes to ensure they are OK.)
BitTorrent solves both these problems and will reduce the amount of noise in this thread from "please send me links" and "pm sent" replies. Bottom line: if you are technical enough to code your BMW, you should be able to download these files, rename them and input them into a BitTorrent client.
One more point: as a courtesy to others, PLEASE SEED THESE FILES for the duration. I will seed these long enough for them to get some traction, but if it turns out I am alone supplying bandwidth, I will stop seeding them. With enough long-term seeders, downloading these files should be both fast and reliable.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
MY19 X3 M40i:
Produced: 2018-08-15; Delivered 2018-08-22
      01-28-2013, 02:16 PM   #2357
theothernguyen
Drives: '12 Jet Black 328i Sedan
Awesome! Any way we can get this put on the front of the thread and keep that updated? Like a Wiki post? I will contribute to seeding what I can tonight!
      01-28-2013, 03:27 PM   #2358
GaborB
Belgium
Drives: F30 316d
Originally Posted by GaborB View Post
Last week the dealer reprogrammed my car due to power steering issue, which action unfortunately upgraded my integration from F020-12-03-520 to F020-12-11-505. With this obviously I lost all my previos coded values and can't any longer use my old 46.6 data files.
Can I please get a link to the newest ones and maybe an up to date E-sys as well?
Thanks.
I was able to restore most of the previous codings I had, but I want more.
If the hardware in the car allows, I'd like to still enable:
- Live or Internet
- Voice control (i have button on steering, but seems not functioning)
- Album art from USB
I have the following options in SALAPA-Elements:
1CA, 205, 216, 230, 249, 255, 258, 2H3, 2PA, 320, 3DZ, 403, 420, 423, 431, 441, 465, 481, 493, 494, 4AE, 4CE, 4DM, 508, 520, 521, 534, 544, 548, 563, 5DC, 606, 698, 6AA, 6AB, 6NH, 6WA, 7S2, 7VB, 853, 880, 8KA, 8S3, 8SM, 8V1
Car ECUs:
ACSM, DME, DSC, EGS, EKPM2, EPS, FEM_BODY, FEM_GW, FZD, GWS, HU_CHAMP2, ICM, IHKA, KOMBI, REM, ZBE2
Any suggestion how to code them?
I was changing a few values for Live and Album art, but no success yet.
Thanks.
      01-28-2013, 04:13 PM   #2359
theothernguyen
- Live or Internet
Car ECUs:
Thanks.
From a previous post,
It seems:
Radio Professional+6NH=No combox
606+6NH=No combox
609+6NH=Castrated combox.
Thus, there would be no way for you to get album art over apple white USB cable without a combox.
Are you able to physically check underneath the floorboard in the trunk and look for a combox (you simply lift up the floor and pull out the cover in the trunk)? it looks like this http://i180.photobucket.com/albums/x...iri/Combox.jpg
Directions to add Album art, Bluetooth audio streaming and white apple USB cable capabilities are here if you have the combox:
http://www.f30post.com/forums/showpo...postcount=2041
and
http://www.f30post.com/forums/showpo...postcount=2043
      01-28-2013, 04:21 PM   #2360
GaborB
Belgium
Drives: F30 316d
and
Thanks, but I'm not using iPod or iPhone. I wanna have album art from a USB stick, and I have jpg cover picture added to tags by mediamonkey.
I have no combox in the trunk, but as far as I recall, some of the members were able to code album art with similar car config, I just don't seem to find the steps/coded values.
      01-28-2013, 04:49 PM   #2361
Yobyot
Yobyot's Avatar
490
Thanks for seeding.
The forum sysadmin would have to move this post -- and the thread is already a sticky. I don't know of another way to let people know, but when people come here and ask for the files, the best thing to do would be to reply with a link to the post that has the .torrent files in it.
That way, when this thread grows to 200 pages, there's likely to be a recent reference to the post in the last couple of pages.
MY18 X3 30i:
MY19 X3 M40i:
      01-28-2013, 05:18 PM   #2362
Frogman
Drives: 2012 F30 328i
You could start a new thread and maybe we can get it to be made sticky!
      01-28-2013, 07:39 PM   #2363
XmX32
I'm have E-sys v 3.22.5 and don't seem to have an EDIABAS folder, i'm a little clueless as to why it didn't come packaged with the E-sys v 3.22.5?
and how do i get it?
      01-29-2013, 03:53 AM   #2364
shawnsheridan
Because the assumption is you started with 3.18.4, which included EDIABAS, and that you were up an running already so that all that was needed was the updated E-Sys.
      01-29-2013, 07:53 AM   #2365
kon
Singapore
20
Drives: F30 310i > G20 310i
stupid question, how do I start seeding without first downloading all over again? I already have the files!
      01-29-2013, 12:06 PM   #2366
Yobyot
Yobyot's Avatar
490
It depends on the client. But they are all the same in essence. Start the client then tell it to "download" to the directory where the files are. If your files are EXACTLY like the ones in the torrent, it should start seeding them. IOW, if all the pieces (the BitTorrent kind) line up, the BitTorrent client will know it doesn't have to re-download them. You should also set the client to seed forever -- some are set to only seed for a percentage of content downloaded.
Thanks for helping out. We're about 48 hours into this and so far, I haven't seen any other seeders. It may be early, but it looks like people are just downloading then stopping. This isn't "the BitTorrent way." This is a community: if you download the files, you should give back some bandwidth in the form of seeding.
MY18 X3 30i:
MY19 X3 M40i:
      01-29-2013, 02:01 PM   #2367
clarence
Drives: F30 328i M-Sport
Not sure abt album art on usb stick, but u definitely can enable BMW Live (ask demge01) with ur spec. All it needs is bt data transfer.
Voice control is I think not possible cos it needs the presence of combox.
      01-29-2013, 04:49 PM   #2368
theothernguyen
This was my exact question as well. I have most of the files already. But didn't get a chance to set up the BT seeding with what I have yesterday since I got home so late. Hopefully tonight.
Are people actually downloading from the torrent? Is there a download count?
      01-29-2013, 06:53 PM   #2369
Yobyot
Yobyot's Avatar
490
As of this moment (01:00 or so UTC on 30 January), there are several people downloading the PSdZData files -- both 48.1 and 48.3. It's sucking up over 2Mbps of my bandwidth, so there are some fast peers out there crankin' up. This means, of course, that if these peers take the whole torrent and then seed it, future downloaders will get the files very, very fast.
MY18 X3 30i:
MY19 X3 M40i:
      01-29-2013, 07:15 PM   #2370
kon
Singapore
20
I'm probably one of them sucking your bandwidth at the moment as I just left it running overnight and couldn't figure out how to line up the files, will probably try later today when I'm home
      01-29-2013, 08:21 PM   #2371
ykau
Drives: F30 320I
isn't torrent from USA to SG is slowed? Copy the files into CD and DHL over is even faster! lol
      01-29-2013, 09:31 PM   #2372
reidpath
Drives: 328i
I'll start seeding from my fios shortly. 150/75
      01-29-2013, 11:14 PM   #2373
hirokouji
Drives: 320i Sport
Hello.
I've coded a FEM_BODY.
Then, the door is now locked automatically start running.
I do not have code there.
What would I do I undo.
E-sys3.18.4
48.2
      01-29-2013, 11:26 PM   #2374
Frogman
Originally Posted by hirokouji View Post
Hello.
The FEM_BODY coding sometimes resets some settings. This happens to me too.
Go to Settings -> Door Locks and clear the "Lock after start to drive". Some other settings may have changed too.
Sometimes when I code, I first save the profiles to a USB stick, then code, then restore the profiles.
Also, sometimes my mirror positions get reset.
      01-30-2013, 08:27 AM   #2375
hirokouji
Drives: 320i Sport
Many thanks
Are there any coding to set the default item of "Lock after start to drive" way?
      01-30-2013, 09:03 AM   #2376
williammm
Drives: BMW F80 M3 (2016)
Is there anyway i can code my side mirror to close automatically when i lock my car via key fob?
