03-02-2018, 03:21 PM | #1 |
Rep 150
F31 335d Hybrid Turbo Build
Evening guys,
I am currently in the process of having a pair of custom made hybrid turbos built for my 335d. They have been stripped and I have decided on the following specs: Small turbo: Billet compressor wheel (non cut blades) 360 degree thrust bearing Not increasing compressor size as I don't want to ruin spool Large Turbo: Bored out to 80mm Custom billet 80mm compressor wheel ( standard is 72mm) with 8 degree blade cut backs 360 degree thrust bearing conversion Rated to 3 bar (standard 2.1/2 bar) Also having manifold ported to match turbos etc too Anyone give me an approximate cost for drive in drive out swap? It's a spare set I've sent away. Also is it worth replacing the oil lines etc? No issues with the ones currently fittedi
335d X drive, Turbo Dynamics hybrid turbos, Wagner Comp Evo2 IC, Torqbyte methanol injection, custom 3" exhaust. 451.2 bhp and 829nm
03-02-2018, 04:30 PM | #2 |
Rep 464
I think you'll struggle to find many folks with that experience, maybe someone can advise what the 'book' job is at a dealer to perform a turbo + manifold swap on the 335d.
Access is often key here, it may only take an hour to physically swap it but 2-3hrs each side to get to it. I'm really not sure, just going from experience of turbo swaps on various other cars on my driveway! Should be no issues using the lines unless there's damage to the faces of the banjo connections, but I would expect them to be fine. It'll be interesting to see how this works out, any ratings on lb/s for that compressor wheel to give an idea of power increase? Is this a proven hybrid? I would be slightly concerned if it spools much later the cut-over might have a bit of a flat spot, but I'm sure good mapping could smooth it out. |
03-03-2018, 02:50 AM | #3 | |
Rep 150
I'm going to see what the max I can do with the DPF / CAT in place and I may look at whipping them off in the future if it's holding the car back that much, we shall see! I've been quite around £800 drive in drive out this far.
03-03-2018, 06:49 AM | #5 |
Rep 150
03-03-2018, 08:14 AM | #6 |
Rep 7,484
03-03-2018, 09:24 AM | #7 |
Rep 9,709
Interesting upgrade.
What prompted you to go for this upgrade? As for costs, I would imagine the plumbing, oil, water, air, exhaust is more complex on a twin turbo, so could take a good half a day. Expensive at BMW rates. |
03-03-2018, 11:15 AM | #8 |
Rep 150
Just want to see what can be done, I know 400bhp is possible with intercooler and map, but may as well try something different - someone's got to lol
03-03-2018, 11:26 AM | #9 |
Rep 19,982
I'm now well over 100k miles on my 335d so if the turbos went then I might be tempted to do something interesting with them if I was having to replace them anyway.
I'd want to keep the dpf and any other emissions equipment intact, so what are you hoping to get power wise going down this route? The other issues is the gearbox and what many miles of high torque outputs does to it. I remapped mine 90k miles ago!
03-03-2018, 11:41 AM | #10 | |
Rep 150
How long theDPF will last with the hybrids fitted and mapped I don't know, only one way to find out lol Main thing is the torque, it will produce figures off the scale but the map will have to be torque limited to protect the box. I'm going to ask for 850nm peak but it will do a lot more. Main thing is the torque will not tail off, it will stay to the redline
03-05-2018, 07:52 AM | #13 |
Rep 278
Really looking forward to seeing the results of this buddy !
you cant go wrong with Rick at Unicorn Motor Developments, one of the best around.
Speed Yellow 435d GC
400 BHP & 839NM My Rare Bmw Visit: http://f30.bimmerpost.com/forums/sho...8#post21668058 |
03-05-2018, 08:11 AM | #14 |
Rep 8,495
Serious mod !
Will be interested in results and review once it's all in.
03-05-2018, 08:13 AM | #15 |
Rep 150
Yeah im a little nervous that I'm spunking two grand on something that's not really been done as yet but someone's gotta try it!!
03-05-2018, 09:01 AM | #16 |
Rep 2,152
there is a guy on the facebook pages from algaria or something he has hybrids but he has dpf delete etc might be worth hunting him down
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
03-05-2018, 09:26 AM | #17 |
Rep 150
Any links would be great not seen it...
03-05-2018, 10:17 AM | #18 |
Rep 8,495
Pioneers are to be applauded
03-05-2018, 11:08 AM | #19 |
Rep 1,314
Have a look on the E90 site as well. Lots of American 335d run modified turbo's and over 480BHP......yes that's right 480!!!
http://www.e90post.com/forums/showthread.php?t=1213093 |
03-05-2018, 11:14 AM | #20 | |
Rep 150
03-05-2018, 12:07 PM | #22 |
Rep 150
Hence the pioneering spirit lol
