06-21-2018, 11:47 PM | #45 | |
Rep 2,271
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
06-21-2018, 11:55 PM | #46 | |
Rep 193
That said.. Now I know the softness is intentioned I actually like it, why.*not* enjoy the softer ride with less wheel crash in every day urban roads, and switching to sport on the motorway for tighter steering and added over taking power, and for the occasional time I have to go on country roads. Leeds is notorious for potholes, many old roads in offer suburbs still have cobbles lol. The district is much much larger than the urban portion meaning much money goes on maintaining the many rural roads Any one any idea on what the metal thing is? Some googling shows it may be a 'valve stem' for improved visuals that can be removed... But I'm guessing they'll have to take the front tyres off again when doing it... Increasing the risk of potential alloy scatches If they c are valve stems they look old so I wonder if they were put in with the original owner,rather than added with |
06-22-2018, 12:12 AM | #47 | |
Rep 2,271
With hitting the stick to the left you don't need to change up/down. You can if you want to but left stick puts the gearbox into sport while auto mode is still engaged. You will see an S and a number appear in the instrument cluster.
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black Last edited by Junebug85; 06-22-2018 at 12:18 AM.. |
06-22-2018, 12:19 AM | #48 | |
Rep 193
And what do I do then.. As it means the 4 petrol stations I tried, the metal casing goes so far up, the air hose end wont go down enough to make a full seal to fill air, only letting air owt. [ although the pump used at the tyre place worked fine] What do you recommend I do? Hunt for somewhere that will fit? Trouble is, each time I test somewhere the air drops a bit more, so I couldn't keep going back to the the tyre place. Unless I get them to fill to the correct amounts, and go back every 4-6 months or so, or whenever one gets too low, and give them a fiver to top them all back up? In fairness I only tried two places, shell and sainsbury's. Perhaps I should try a morrisons and or esso garage air pump. Also if the only option is to remove them, can they easily be kept and re clipped in in the future? And will I be able to disable / silence the warning on the idrive Both front tyres are reading 2.6 bar. (as opposed to 2.8 bar as recommended on the labelling), so I could just leave them. Then ensure they do the back ones to 3.0 bar as recommended. They did mention they always fill a little lower than what it says as it's better.. He said they fill all tyres generally to 38psi, which is 2.6. UPDATE: I found that turning the petrol station pumps round, using the other end, although fiddley as you have to feed it through the alloy, works like normal. So no issues now. All sorted and happy. Just to get the rears changed, then alignment. Then will look at getting the rears tinted, as for some reason they didn't come with privacy glass which I only noticed the other day. Last edited by madlad2000; 06-22-2018 at 05:41 AM.. |
