11-17-2017, 08:51 AM | #1 |
Rep 1,597
Horn when removing airbag from steering wheel
Hello. I am trying to remove the steering wheel in an F30.
Is the horn supposed to blast when you insert the screwdriver into the holes under the steering wheel to bend the spring clips holding in the airbag? |
11-17-2017, 09:04 AM | #2 |
Rep 474
Drives: 2014 328D xDrive
When you insert the screwdriver; you are pulling the airbag backwards by moving the spring clip; in other words compressing the connectors for the horn.
Yes; it will sound when you do that. Pull the fuse first so you don't have any airbag accidents. |
BMWILUVU809.00 |
11-17-2017, 12:24 PM | #5 |
Rep 1,597
I will disconnect the battery next time. I just wanted to make sure it was not shorting out or something else because just touching the screwdriver against the clip or something near it caused the horn to blast which I thought was odd.
11-17-2017, 02:08 PM | #6 |
Rep 536
Drives: 2013 335xi Alpine White
Nothing is more surprising than an airbag going off in your face because you didn't disconnect the battery first...
Side benefit - horn doesn't beep when you take airbag out |
