BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > F31 335d Hybrid Turbo Conversion
Studio RSR
      03-02-2018, 02:34 PM   #1
blacky999
blacky999's Avatar
Drives: F31 335d M Sport
Evening guys,
I am currently in the process of having a pair of custom made hybrid turbos built for my 335d.
They have been stripped and I have decided on the following specs:
Small turbo:
Billet compressor wheel (non cut blades)
360 degree thrust bearing
Not increasing compressor size as I don't want to ruin spool
Large Turbo:
Bored out to 80mm
Custom billet 80mm compressor wheel ( standard is 72mm) with 8 degree blade cut backs
360 degree thrust bearing conversion
Rated to 3 bar (standard 2.1/2 bar)
Also having manifold ported to match turbos etc too
Anyone give me an approximate cost for drive in drive out swap? It's a spare set I've sent away.
Also is it worth replacing the oil lines etc? No issues with the ones currently fittedi
335d X drive, Turbo Dynamics hybrid turbos, Wagner Comp Evo2 IC, Torqbyte methanol injection, custom 3" exhaust. 451.2 bhp and 829nm
      04-06-2018, 06:25 AM   #2
DThr33
DThr33's Avatar
634
Drives: F80 M3
Any updates on this mate? Curious to see how you got on
      04-08-2018, 04:41 PM   #3
blacky999
blacky999's Avatar
Car has just gone in for fitment
Meth install going nicely too tho lol
DThr33634.00
      04-08-2018, 04:53 PM   #4
blacky999
blacky999's Avatar
Some pics from Turbo Dynamics of the turbo build
DThr33634.00
      04-10-2018, 06:10 AM   #5
DThr33
DThr33's Avatar
634
Drives: F80 M3
Jesus christ haha very interested in this build now! How much is the turbo work running you?
      04-10-2018, 08:01 AM   #6
blacky999
blacky999's Avatar
Small turbo off so far
      04-10-2018, 10:30 AM   #7
n00bkiller944
Drives: '14 328d M Sport
This is awesome!
      04-10-2018, 04:27 PM   #8
blacky999
blacky999's Avatar
Big Hybrid turbo fitted to the polished and ported manifold and one of the small turbo with the electronic control unit attached ready for refitment.
Down pipe was apparently a complete nightmare to remove from the turbos, let's hope it's kinder on the re fit
      04-10-2018, 06:26 PM   #9
F30inthe6ix
F30inthe6ix's Avatar
Drives: 2012 F30 BMW 328i 6MT
Originally Posted by n00bkiller944 View Post
This is awesome!
Agreed!
2012 F30 BMW 328i 6MT - Alpine White on Coral Red - Harmon Kardon Sound - Premium Package - Executive Package - BMW Apps Package - Sport Package - Dinantronics Sport - Dinan Springs / Bump Stops
      04-11-2018, 11:01 AM   #10
blacky999
blacky999's Avatar
They are in
      04-11-2018, 12:45 PM   #11
blacky999
blacky999's Avatar
Done
      04-13-2018, 02:58 PM   #12
blacky999
blacky999's Avatar
Car collected and drives perfectly didn't even throw a single error code after fitting!! Is making a cool whistle under load now (not a leak!) and hits peak boost much quicker. Just need to finish the meth install and then get her mapped.
Had a play with the 0-60 timer on the P3 gauge, it felt quick but not sure how accurate it is!!
      04-14-2018, 10:21 AM   #13
Ajs_435d
Ajs_435d's Avatar
355
Drives: 435d m sport m performance
Superb!
      04-16-2018, 08:32 AM   #14
blacky999
blacky999's Avatar
Little video for those who are interested
DThr33634.00
      04-19-2018, 04:33 AM   #15
DThr33
DThr33's Avatar
634
Drives: F80 M3
Damn I should've checked this thread earlier, saw your car at the ace cafe meet! Would've loved to see the power in person haha
      05-01-2018, 07:48 AM   #16
blacky999
blacky999's Avatar
Mapping day on Thursday
      05-02-2018, 04:21 PM   #17
Ako2k6
Drives: BMW f36 430d
Who’s doing the mapping mate ?
      05-02-2018, 11:17 PM   #18
blacky999
blacky999's Avatar
Rick at Unicorn motor developments
      05-03-2018, 11:26 AM   #19
Ako2k6
Heard nothing but good things about rick at unicorn. I will be getting my map done by him
      05-03-2018, 03:36 PM   #20
blacky999
blacky999's Avatar
So today was a nerve racking mixed emotions kind of day. The car laid down some solid initial figures:
I didn't get full figures, didn't want to hassle the guys working on it too much but:
373.48 without the meth (boost leak)
391 with the meth (with boost leak yet to be discovered) (graph below only one I managed to get)
Then as much as they tried the boost leak was uncontrollable and pretty bad so peaked at
401 bhp and 835nm
Cars mapped by Unicorn usually run around 2.1 bar of boost, they were requesting 2.5 bar form mine but only seeing 1.7 due to the leak and it still made 401 and 835.
Leak was that bad it was also forcing meth out in to the air on the dyno pulls 😩
Torqbyte meth controller being fitted the. Car is going back to Deutsch Tech for the intercooler end tank to be drilled and tapped to accept the meth nozzle. Currently running twin nozzles but was advised that is OTT.
I have a brand new OEM boost hose to go back on so watch this space 🙈🙈🙈
      05-07-2018, 11:19 AM   #21
n00bkiller944
Where was the boost leak from?
      05-07-2018, 04:17 PM   #22
blacky999
blacky999's Avatar
Boost leak was from Main intercooler hose to inlet, prior to inlet air temp sensor. These pipes eal well but after being on and off a few times it weakens the seal.
Mine was blowing boost and meth out of the leak so had to abort.
New hose going on and the meth nozzles being relocated to the intercooler outlet once it's drillled and tapped. Plan is to run a single large nozzle as two seems over kill. New Torqbyte controller is another level!
