      Yesterday, 06:09 PM   #7349
pdk42
Drives: 530d touring
Hi - another new F31 owner here ready to do some coding mods. A big thanks to all the contributors here - where would we be without you?
Could someone PM the details of where I can get the E SYS software and data?
Thanks,
Paul
pdk42 is online now
      Yesterday, 07:36 PM   #7350
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Thanks,
Paul
PM sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
shawnsheridan is offline   United_States
      Yesterday, 08:42 PM   #7351
hooolala
Drives: 2011 BMW 550i
i also need help with getting the most updated E SYS software and data, please help. thanks
hooolala is offline
      Yesterday, 08:55 PM   #7352
shawnsheridan
PM sent.
      Today, 01:18 AM   #7353
10nelyboi
Drives: 2012 - 335I
I would need to connect with Team viewer and have a look. Something is not right. I suspect either an ECU is missing its CAFD or it has corrupted CAFD.
HI Shawn,
I having the same issue with errors of DriveTrain and Fuel System. I tried to clear the CEL using EXTERNAL APPLICATION --> Transmitter in Esys. So far no luck.
This happened during the process of me trying to VO code the DME module. Now I can't clear the errors. Can you please help?
10nelyboi is offline
      Today, 01:19 AM   #7354
shawnsheridan
Originally Posted by 10nelyboi View Post
HI Shawn,
Does your DME still have a CAFD file, and if so, what is the name of it?
      Today, 01:23 AM   #7355
10nelyboi
Drives: 2012 - 335I
it looks like the CafD is gone
      Today, 01:53 AM   #7356
shawnsheridan
Well, that's a problem. You need to inject CAFD into DME, and then VO Code DME:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on DME => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on DME (the ECU itself not the underlying CAFD) => Select CODE.
To determine your I-Level, go to VCM Module => VCM Master Tab => click Read under I-Steps. The I-Step (current) is the one you want to match when you select the CAFD from the "Detect CAF for SWE" options.
Here is where you may have a problem. You cannot run the motor when you VO Code DME, and your battery may not be putting out enough Voltage to enable coding. If Coding fails, you need to put car on charger, or run jumper cables from it to another running car.
      Today, 02:46 AM   #7357
10nelyboi
Drives: 2012 - 335I
Got it working!! and the errors are gone.
Thank you Shawn. Talking about delicate service at 12AM (PST) time, i'm sure its 2AM your time. We won't even get that kind of service on any where else, especially when we're not even paying.
So the lesson of the day is DO NOT CODE THE "DME" MODULE. PERIOD!!!
I was trying to change the FA and VO the car, and it requires VO codes the "DME" module. I learned it the hard way.
      Today, 06:16 AM   #7358
shawnsheridan
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
