10-07-2015, 08:40 PM | #1 |
Rep 75
Center Channel
Has anybody upgraded their center channel? The obvious issue is the tight space, but it looks like you could trim out a lot of dash material and space the speaker up about 10mm and make a focal 4" fit.. its tough to say for sure.
Anybody done it? |
10-09-2015, 12:19 PM | #6 | |
Rep 558
10-22-2015, 06:20 PM | #8 |
Rep 1,805
You might think i'm nuts but the system sounds better with the center channel unhooked.
I have H/K, then I did Bav Stage 1, then I unhooked it and that sounded best.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
10-24-2015, 08:29 PM | #10 | |
Rep 228
oh, its a center channel and that's what they do |
01-27-2016, 06:19 PM | #11 |
25cent millionaire
252
Rep 1,220
Drives: 2020 m4 comp vert
why didn't you just spend 300bucks and put in a ms 8. way better and easier to due..
02-01-2016, 07:11 PM | #13 | |
Rep 346
It is my first ride with center channel and I used to play passive front setup and the added center channel makes the sound stage greater SQ than my passive setup. IMHO! |
02-01-2016, 07:21 PM | #14 | |
Rep 346
The picture below seem like taken from a car already with factory center channel as it is quite hard or near impossible to cut it to such nice edges. What I did was purchased a HK center channel cover and removed the TOP metal mesh. It is secured by many metal tabs that you just bend it and there is a little bit of adhesive and pop it out. I made a photocopy of the frame and then cut out to make the template. Be sure to have the whole outline as it will guide against the recess on your dash to get the alignment done up. I tested it again and again by fitting the speaker cover frame to my template. Once I am happy, I made the template out of hard cardboard. My installer and I then removed the whole dashboard and he traced against my template and used a cutter to open up the dash. It is rather soft material so using a Dremel tool is not going to help. After test fitting and trying many times, he is satisfied that the cover secures nicely. Last edited by MSportTune2; 02-01-2016 at 07:38 PM.. |
02-01-2016, 07:36 PM | #16 |
Rep 346
Final look. Speaker cover attached without any tape. Important to take your time to make the opening for the clips just right to achieved this.
closetwagonlover37.50 |
