02-13-2018, 06:26 PM | #23 |
Rep 1,380
Has anybody tried or seen in person their spoiler? http://www.maxtondesign.co.uk/produc...bmw-4-f32.html
It's very much like the on the CS which I saw today.. I'm really tempted to get the molet version and then skin it in oem matching carbon fiber
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
02-14-2018, 09:02 AM | #25 |
Rep 99
02-17-2018, 02:10 PM | #27 |
Rep 99
02-19-2018, 01:00 PM | #29 |
Rep 352
Had a couple of PM's mid last week, with a little advice to how I fitted it.
i.e. Its a pain to put all the bolts that Maxton give you, so I just put a couple where i could easily reach. Then used VHB on the full width and a lot of self tapping screws. Since then nothing!
2019 G01 X3 M40d
02-21-2018, 03:08 AM | #33 |
Rep 1,151
Drives: F90 M5 Comp (Evolve Tune)
no not had chance to fit yet, adding wheel spacers tonight and had an alloy refurbished, but want to attempt at weekend, was too busy this weekend.
02-25-2018, 08:26 AM | #41 |
Rep 965
Drives: 2016 F36 435x MSport
silly question, but between this and the oem splitter, do they use existing mounting holes on the msport bumper or do you need to tap new ones?
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
02-25-2018, 03:09 PM | #42 |
Rep 1,151
well thats the pain, when i fitted the M Perf splitter to my m235 dead easy, this spoiler has shite instructions, not helpful in any way. none of the drill areas match any existing points the bolts are huge great things which i didnt even use, you kinda make it up as you go and drill using your brain at either end and middle make sure well cleaned before you stick down cover in 3M, even pairing it up is tricky, i pulled of a tint bit of tape in middle and either end first and tacked the thing on one end then middle working way along so you can pull off quick if not right. Then when gently held on stand back check on even each side and pull rest of tape off. Not mega hard but fiddly unlike the M perf one, But i wanted a subtle look and small under lip similar to cs m4, been over speed bumps today and not issues (yet). I have H&R springs and 12 and 15 mm wheel spacers
Soul_Glo13343.50 |
