01-16-2024, 04:26 PM | #221 |
1997
Rep 2,179
[QUOTE=ABall;30818903]
https://www.ebay.co.uk/itm/173560991...Bk9SR_iV_cWiYw It is a very good fit; fits better than the OEM BMW one I bought a few months back TBH as it fills all the corners etc I've kept the eBay one as it comes in handy to cover the backs of the seats if/when I have them folded down for tip runs or when we go camping etc and I want to protect the interior
01-17-2024, 01:49 AM | #222 | |
Rep 84
[QUOTE=danb1979;30819299]
01-17-2024, 09:53 AM | #223 | |
1997
Rep 2,179
[QUOTE=ABall;30820438]
Popped it on your other post as well. But this is that boot liner for your F30 https://www.ebay.co.uk/itm/173925076...Bk9SR6SRnIKjYw
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 Last edited by danb1979; 01-17-2024 at 09:58 AM.. |
ABall46.00 |
01-17-2024, 03:26 PM | #224 | |
Rep 84
[QUOTE=danb1979;30821195]
danb19791997.00 |
01-22-2024, 02:58 PM | #225 |
Rep 84
[QUOTE=danb1979;30821195]Thanks again for this, should of taken a pic but i was too exited driving the car around. The mat is a fantastic fit, I went shopping and through a case of beer in the boot, the best thing about the mat...... the beer doesnt slide around the boot on it, worth it just for that!
danb19791997.00 |
01-23-2024, 01:52 AM | #226 | |
Rep 180
danb19791997.00 |
01-23-2024, 03:56 AM | #227 | |
1997
Rep 2,179
Yup; I've run a stud conversion and spacers on every BMW since 2012 and they make a superb difference; offer a better turn-in feel too... I've only ever run 12-15mm and never wider; they've been spot on s hoping the 12mm spacers will offer the right kick out for the 18x8 wheels I'm running I'll get them fitted as soon as I'm able to move more
01-30-2024, 11:34 AM | #228 |
1997
Rep 2,179
Finally; 1st time in nearly 3 weeks, been able to give the BMW a wash (albeit contactless)... Not been able to touch the car since my op; but able to move more freely now and should be fine for driving in the next day or two...
It needed a wash; grey with just cack from the skies; it's been sat on trickle since 17th! It'll be filthy again in no time; but it keeps my OCD happy I was going to get the ZF service done before we head up to The Highlands on 11th Feb but haven't got the time now so it's booked in for when we get back and then I'll look to get it remapped and the box mapped too I think...
Alscoob2185.50 |
01-31-2024, 03:26 AM | #229 | |
Rep 3,111
danb19791997.00 |
01-31-2024, 03:45 AM | #230 | |
1997
Rep 2,179
I've 12mm spacers and the stud conversion in the garage; so will get them fitted as soon as I can
Alscoob2185.50 |
01-31-2024, 09:18 AM | #232 |
1997
Rep 2,179
A much better alternative to longer bolts; tightens down thew wheel/spacer from both sides and not just one
But also makes removal of the wheel/refitting of the wheel much easier too; if you've issues like me and take the wheels off regularly to clean them properly
01-31-2024, 11:14 AM | #234 | |
Rep 214
I can actually add another advantage of studs and nuts. Since BMW swapped over to (ridiculously!) fine threads on the 14 1.25 standard it is surprisingly easy to crossthread a wheel bolt. And if that happens the only proper recourse is to replace a hub at considerable hassle and expense. (ask me how I know ). So I wish I had known this sooner!. I swap wheels out pretty regularly on the summer / winter tyres. |
danb19791997.00 |
01-31-2024, 11:51 AM | #235 | |
1997
Rep 2,179
And for me, as said above; because I swap from summers, to winters, back to summers etc and take the wheels off to clean them quite often; it makes my life easier
01-31-2024, 11:52 AM | #236 |
1997
Rep 2,179
crAbb1246.00 |
02-01-2024, 03:24 AM | #237 | |
Rep 1,117
Two threaded interfaces to work loose from heat cycling vs one. There is no mechanical advantage of one method over the other in terms of strength though. European car makers just favour bolts over studs + nuts as it removes one threaded interface from their inventory, so it's purely for profit as you say. If you don't have buy in a billion nuts, the savings add up. Personally I have no issue with wheel bolts but I can see the appeal of studs. Another advantage is the studs are static and only the nut wears out, whereas constantly changing wheels with bolts wears out the threads in the hubs as well as the bolts, and as you've found, increases the risk of a cross thread! |
danb19791997.00 |
02-01-2024, 07:06 PM | #238 |
Rep 185
Mmmm, jury is out with me.
A few statements I'm struggling with are :- A stud and nut tightens from both sides ? How can this be, the stud is static and the nut moves down it, the same as the head of the bolt, so both are clamping from the outside. Studs are static and only the nut wears out ? How can this be, the threaded hole in the hub is static in relation to the bolt as well. Maybe its the engineer in me, but I cant see a thread in either the hub or on the bolt wearing out through removal and replacement as long as care is taken not to crossthread or over tighten them. I do get the bit about it being easier to mount/dismount the wheel as especially with the 370mm brakes its easy to drop the wheel onto the caliper when removing, but I dont think normal length studs will avoid this. |
02-01-2024, 11:30 PM | #239 | |
Rep 180
02-02-2024, 02:46 AM | #240 |
1997
Rep 2,179
I went off some info I rad on various forums about studs vs wheel bolts; more so with spacers and they do appear to be a better option
My motorsport mechanic pals recommend them too; more so those who track their cars (obviously they help a lot with the removal/refitting of wheels etc) I'm not an engineer; I'm not going to pretend to be, but they're my preference now and have run them for years with zero issues If I wasn't going to run spacers; I'd more than likely not bother with them
02-02-2024, 04:43 PM | #241 |
Rep 192
I did the same - cross threaded a bolt when changing over to my winters last year.
Unfortunately it was getting dark and I had to get on the road, so I spent another hour grinding down another OEM bolt and threaded it through from the rear of the hub to self tap it back straight. Then temporarily fitted a longer bolt I’d just removed along with the spacers. Thankfully avoided disaster, just. |
danb19791997.00 |
02-03-2024, 04:37 AM | #242 | |
Rep 1,117
I did actually have to replace the hubs on one of my old VWs due to frequent maintenance and wheel swaps etc. Get a bit of grit in a bolt thread from laying them on the ground and it can quickly gaul out the threads. It would have been easier (and considerably cheaper!) to replace the studs and nuts in that situation. Anyway, most of us are careful and I wire brush the bolts now, and use a tiny amount of grease on the bolt to prevent rust seizures. |
danb19791997.00 |
