BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Adaptive Headlights 2 Different Color Temps
European Auto Source
      11-20-2017, 10:35 AM   #1
kern417
Drives: 2018 440i
Like the title says, I have the Adaptive LED Headlights and the inside lights are more of a blue "6000k" temp while the outside lights are a whiter "4300K" temp. Does anyone else's have the same color difference? Is it something I can change with coding? I personally prefer the blue tint. It's even more awkward since it is also offset by the dull looking icon halo DRL, but i'm pretty sure that can be fixed with coding. I just haven't done it yet.
I tried to take a picture but my cell phone makes to many automatic adjustments an accurate representation of lights properly.
      11-20-2017, 12:19 PM   #2
Poon Stick
Two many diffs
Drives: '16 340xi MPPSK 6MT
Can't change the colour of LEDs with coding - they are what they are.
      11-20-2017, 01:05 PM   #3
Blubaron79
Blubaron79's Avatar
Drives: '15 335 XDrive
So your are saying the halos are a different color than the projectors?
I've never noticed this.
'15 335 XDrive: Glacier Silver, MSport, 19's, every option (except ACC and DAP), MPPK, MPE, black grille, splitter, side sills, CF Spoiler, clear bra.
Previous: '14 435 F32 xDrive; '09 335 E92 xDrive
      11-20-2017, 01:10 PM   #4
kern417
Drives: 2018 440i
Yes, the halos are a dull white. I have read that you can change this with coding, because the halos actually dim when the headlights are turned on. They are brighter when the headlights are off, and the coding should make them stay at 100% brightness when the headlights turn on so they will *hopefully* match the color.
i'm more concerned about the actual light though. Like if you reference this image, on my car the light on the left is more of a neutral white while the light on the right has a blue tint.
      11-20-2017, 01:28 PM   #5
kern417
Drives: 2018 440i
I thought i'd try to take pictures again in the daylight, and it's easier to see the actual color of the LEDs with the ambient lighting outside. It's still not as obvious in pictures as it is in person, especially at night. Anyway, if anyone can confirm (or deny) that this is normal i'd appreciate it. Like I said, it's like running one light with a 4300k bulb and the other with a 6000k, so very noticeable.
      11-20-2017, 02:39 PM   #6
vgore
vgore's Avatar
Drives: 2015 328xi
That doesn't look to bad. I think the angle at which you look at the headlamp makes it appear yellower. Do you see a difference in beam color?
      11-20-2017, 05:27 PM   #7
kern417
Drives: 2018 440i
Not so much, but both lights are aimed at the same direction so I wouldn't expect to.
And like I said, the difference is very apparent in person. I just tried my best to capture it in photos. Also it's not just apparent when looking into the housing so it's not the angle. If you stand over the light and look down, you can see the light's reflection on the lens and you can see the color difference. I have another idea to take pictures tonight that may show it better by separating the lights with cardboard or something.
      11-20-2017, 07:54 PM   #8
kern417
Drives: 2018 440i
I tried taking more pics by holding up a white piece of paper in front of the lights, but pics just don't come out the way it actually appears. You can definitely tell that the beam from the inside light is a different color than the beam from the outside light.
      11-20-2017, 09:30 PM   #9
Blubaron79
Blubaron79's Avatar
You'll notice when the DRL's are set to full at night they wash out with the headlights.
      11-21-2017, 08:42 AM   #10
kern417
Drives: 2018 440i
i'll keep that in mind.
bump for feedback from anyone with adaptive headlights
      11-21-2017, 10:39 AM   #11
Poon Stick
Two many diffs
You can definitely code for brightness, but it won't affect the colour of the lightoutput from LEDs.
It's not like with Halogens where if you apply more voltage they get hotter, giving a whiter and brighter light.
LEDs get brighter with pulse width modulation (On more/longer times per second) but their colour temperature stays the same.
Your car is not a lemon just because the lights are slightly different colours. Head to your dealer and see if they have another car with adaptive LEDs and see if its the same.
      11-21-2017, 11:51 AM   #12
vgore
vgore's Avatar
Drives: 2015 328xi
^+1 What he said.
Head to the dealer for faulty lights. You should be covered under new car warranty.
      11-21-2017, 11:59 AM   #13
kern417
Drives: 2018 440i
Yeah, I get how LEDs work, just wasn't sure if the color was was a result of different output from the lights. I'm more familiar with HIDs that change color as the light is dying. I am still trying to find details on if the 2 lights operate differently or not, because otherwise it doesn't make sense for them to be different colors by design. But it's weird that the color difference is symmetrical between both headlights. Anyway, I only found coding details for the halos and haven't played with it yet. I'll keep searching for coding the actual low beams if that's possible.
And I never said my car was a lemon. I'm just asking if it's normal or if anyone else with adaptive lights see the same thing. I've had the car for 2 months so I don't plan on going to the dealership any time soon, but if it is an issue then i'll bring it up at my first service next year. So it's easier to do some investigation from my couch.
I just wish at least one person responding could answer main question I asked.
      11-21-2017, 12:00 PM   #14
kern417
Drives: 2018 440i
Originally Posted by vgore View Post
^+1 What he said.
Yeah, if I can confirm it's an issue I'll go that route next year. I just don't think it warrants a separate visit.
      11-22-2017, 04:49 PM   #15
Poon Stick
Two many diffs
Not harping on you, just addressing the other comment to check your state's lemon laws...
Just looks like it's simply that the colour temp of the LED DRLs (halos) is different than that of the headlights. You might just be the first to notice / get bugged by it.
Might just have to live with it
      11-22-2017, 10:18 PM   #16
kern417
Drives: 2018 440i
Thanks, but it's more than the halos. The lights in each reflector are different. If I have to live with it, it's not the end of the world. But I haven't seen it in any other pictures and would like to have it replaced with matching ones for my OCD.
      11-22-2017, 11:03 PM   #17
Wires
Drives: 2016 340i xDrive
It's probably the difference of the straight reflector in the main light vs the light pipe in the halo (not an actual color temp difference).
Really, the only time you would notice that is when someone jacks your car and is about to mow you down.
Get behind the steering wheel, drive it like you stole it, and it becomes a non-issue.
      11-23-2017, 10:17 PM   #18
kern417
Drives: 2018 440i
I'm going to say this one more time. it is not, i repeat, not the halos. when i hold a piece of white paper in front of the headlights, i see 2 different color beams. the difference just gets washed out at a distance so it's not apparent on the street. but it is very obvious when looking at the headlight housing.
      11-29-2017, 10:25 PM   #19
ScottFree_
ScottFree_'s Avatar
Drives: 2016 328i XDrive
[img]https://lh3.googleusercontent.com/fO...=w1279-h960-no[/img]
[img]https://lh3.googleusercontent.com/Ut...=w1279-h960-no[/img]
I can see the difference in color temp between the two.
From the pic I wouldn't notice unless you pointed it out but I'm sure it's more prominent in person. You're not crazy
Since we apparently have the same vision, I was going to compare mine but I have the standard LEDs (non adaptive).
Didn't realize adaptive came with a more angular shape than the LEDs I have..my design's a bit more round..I like yours more.
Anyways if it were me, I would eventually compare to another car to confirm a defect or if it is by design..it would bother me after a while.
      11-29-2017, 10:44 PM   #20
Wires
Since both sides are the same color, I would say it's "by design". The outers are for high beams, so they probably have different intensities.
I'm still not sure why it matters though. OCD, sure. I get that. But it's not like you stare at your headlights.
      11-30-2017, 12:38 AM   #21
ScottFree_
ScottFree_'s Avatar
Good point, now have to check mine when I get a chance.
Definitely OCD but owning nice cars/things can do that to a man
      11-30-2017, 09:03 AM   #22
kern417
Drives: 2018 440i
that's my thoughts as well. if it was only one headlight then i wouldn't even ask, but for both lights to do it makes me think it might be designed that way.
And I assumed that the outer beams might have a different function, but according to BMW both lights have the same function so it just doubles the light output. Only the halogens have different functions for the inner and the outer lights.
http://f30.bimmerpost.com/forums/sho....php?t=1125534
i'm actually going to the dealer for separate issue this weekend, so i'll check other cars they have. i know it's a little issue but every time i walk up to my car and unlock it, i see the lights. it irks the crap out of me. what's really funny is i have a clear bra that only covers half the hood, but the line hasn't bothered me a bit. and that's if i ever notice it that's just how my brain works.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
