05-28-2016, 09:13 AM | #1 |
GW 2010 BMW 125i E82 - BMWP Carbon Mirrors, Grills
Rep 11
M performance front disc alternatives?
Hi guys,
I've bought some M performance calipers (370mm versions), and I need to get some discs. I was considering the dimpled/ groved M Performance discs but I've heard they make a "whoosh" noise whilst driving and they also cost a fair bit, too so I've been looking for alternatives I.e. Non BMW versions. But after looking for sometime I'm struggling to find anything! The closest I have seen which may or may not fit is from a company called ZimmerMann. They do these in blank, drilled, slotted and drilled. Link below. http://m.buycarparts.co.uk/zimmermann/7890750 Does anybody know if these are the same size/spec as the m performance discs and if there are alternatives out there can you please point me in the right direction? Thanks! Mike Last edited by Mike_RS; 05-28-2016 at 09:27 AM.. |
05-28-2016, 11:52 AM | #2 |
Rep 444
I thought BMW had a 370mm rotor off the m sport that lacked the dimples and slots... That is if you want to stay BMW vs aftermarket.
For aftermarket big $ I think ecs has a 370mm two piece rotor as well without the slots. |
05-28-2016, 12:17 PM | #3 |
Rep 11
Thanks, I know BMW sell the plain M sport discs but these are nearly £500! Can't figure out why they charge more than the M performance discs?! I'm hoping to save a little money on discs by going aftermarket.
Can anybody confirm if the ZimmerMann discs in the link are the same dimensions as the BMW versions? |
05-28-2016, 12:56 PM | #4 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
If you plan on buying aftermarket, make sure they have aluminum hats like the OEM rotors do. Otherwise, you'll be adding weight... these discs are already pretty heavy due to their size, you don't want to add more.
Unfortunately, I don't know of an aftermarket rotor that would be cheaper
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
