03-02-2017, 03:41 AM | #1 |
Rep 359
Adaptive Headlight Defective - Make Sense?
When I got my car it had the upgraded headlights, xenoens with nice LED surrounds, unsure if they are the 2016 ones or just xenons? Anyway...
I did the whole VIN de-code yesterday, pretty cool and noticed one of the options was adaptive headlights. As mine keeps giving me the error every time I start it that it is defective (means I can keep an eye on my MPG, miles left etc as the warning takes over) - Would it make sense that the headlights that have been fitted are not adaptive? I just need to code into the car that they are not adaptive? Or are all newer lights adaptive? If i say adaptive once more in a post I may kill myself. Just wondered if I was thinking logically or nonsense. |
03-02-2017, 04:17 AM | #2 |
Rep 13,043
Drives: BMW M340I G20
If you press the BC button it will move the light warning to a triangle and allow you read MPG etc. Are you sure it's not just a blow bulb warning?
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
03-02-2017, 04:29 AM | #4 |
Rep 13,043
What does it say in the warning?
03-02-2017, 04:45 AM | #6 |
Rep 8,062
Why would the headlights fitted be non-adaptive if your car has adaptive as an option? What's coding got to do with anything?
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
03-02-2017, 04:49 AM | #7 | |
Rep 359
And coding side was - if the car is coded for adaptive lights (halogens - unsure if they do adaptive halogens - hence asking) and they have fitted none adaptive xenons (again not sure if they do this - I'm still new to the F30 world) would this cause the error? Cheers |
03-02-2017, 04:59 AM | #8 |
Rep 8,062
But if the VIN decoder lists adaptive headlights as an option then that is a factory-fit option - if they're retrofitted then the VIN decoder will show whatever it left the factory with. There is evidently a fault.
There is no such thing as adaptive halogens.
Ian
03-02-2017, 05:01 AM | #9 |
Rep 175
Strange one this...if the car originally came from the factory with adaptive headlights (which are only Xenon or LED, not halogen) and have been replaced with none-adaptive, I'd be asking questions. Maybe the car had a front end shunt and had parts replaced?
Like you say, may be a simple coding mistake if they have been retro-fitted. Do you have working headlamp washers? As that is probably a good indication whether the car originally came with Xenon headlights or not. Or as said, they could just be faulty?
Current - BMW F32 M Sport
Previous - BMW F10 M Sport |
03-02-2017, 05:04 AM | #10 |
Rep 2,511
So, your car originally came with halogens from the factory and now has upgraded BMW lights which are coded for Adaptive Lights? But, you don't know what units are fitted?
Do you have round rings or not fully round rings. Xenons have complete circles, LED's have non complete circles with a side spur. For adaptive lights you must also have a camera mounted in the driving mirror housing to monitor the road ahead. This should let you know if it's a full retrofit or miss-coding.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
JLR19691877.00 |
03-02-2017, 05:34 AM | #11 |
Rep 359
Thanks guys. Not playing dumb just the F30 world is a far cry from what I'm used to so trying to learn as much as I can!
On the De-Coder website I get - S522 Xenon Light S524 Adaptive Headlights No my car is previous repair so maybe they haven't put adaptive headlights back in! I will check the part numbers today. I haven't noticed any sort of camera in the drivers mirror housing! So again this maybe where things are going wrong! Xenon washers work OK and here is a picture of the lights I have... Again sorry for getting confused on most things just jumping ahead of the gun thinking I know more then I actually do! |
03-02-2017, 05:43 AM | #12 |
Rep 8,062
The VIN decoder states adaptive so that's what it left the factory with. Gives two options:
1) Adaptive lights are fitted but are faulty or the KAFAS camera is 2) Adaptive lights were fitted at manufacture but (possibly as a result of accident damage) some ignorant bodger has fitted the incorrect headlamp assemblies (non-adaptive xenon), looked at the error message and thought: "fcuk it". EDIT - reading your post again, if there is no KAFAS camera in the mirror housing that is even more bizzare. Why would that have been removed?
Ian
03-02-2017, 05:51 AM | #13 | |
Rep 359
LAST alternative is code the car to not think it has them, which I really don't want to do as it came with them from factory I would rather get the parts needed and get it fitted. First thing is to check PN's on headlights to see if they are adaptive version or not. Then work from there. Can see this being expensive! |
03-02-2017, 05:54 AM | #14 |
Rep 8,062
I'd take a picture of the KAFAS camera in mine so you know what to look for but mine is at the dealers today having the steering rack replaced.
Ian
03-02-2017, 07:07 AM | #16 |
Rep 175
The camera is only required if the car is fitted with high beam assist regardless of adaptive or not.
OP, do you have another button underneath the BC button on your indicator stalk? I would assume that whoever repaired the car didn't fit adaptive headlights...
03-02-2017, 07:42 AM | #17 |
Rep 8,062
You can't have adaptive without HBA so any car with adaptive will have the camera.
Ian
03-02-2017, 07:46 AM | #18 |
Rep 359
Ok been to the car on lunch! I could only see a sticker on the drivers headlight and PN is 63117259548 but can't find much on google? I have camera and no sticker on passenger light?
If that Pn doesn't match adaptive we're going down the cheap repair idiot work As for a button yeah I have 2 I think, top one is BC and unsure on bottom one! Will check when I finish! |
03-02-2017, 07:57 AM | #19 |
Rep 8,062
That is a KAFAS camera in your mirror housing, the one flush to the glass is the rain sensor.
Having said that, although that is a camera housing it doesn't look like the camera itself is actually present!
Ian
03-02-2017, 07:59 AM | #20 |
Rep 359
Oh... I will analyse more after work, maybe just a new camer then? Why it would be out I have no idea! Does that part number match that of adaptive lights? I can't find anything online to say yay or nay!
03-02-2017, 08:50 AM | #21 |
Rep 9,709
I know I'm thinking way outside the box here, but perhaps have a BMW service department run a diagnostic on your car?
They should be able to track down exactly what is wrong in minutes. |
03-02-2017, 09:11 AM | #22 | |
Rep 32,881
Kafas is only for speed limit display and/or lane departure warning, and looks like this on mine (i have SLD): screen cap |
