05-04-2018, 05:04 PM | #1 |
Rep 8
Just Installed DINAN Sport on my 330i XDrive Wagon
Had not seen a lot of reviews of the DINAN Sport tune for the B48 so thought I would at least share my thoughts on it,
In nutshell, if you have access to 93 Octane gas and can run the tune in Race Mode at 4.0PSI it is well worth the cost. The Sport+ mode is a noticeable difference, but not like moving to race mode. The biggest difference is the Torque between 2500 and 4500 RPM. As it reaches more RPM it is hard to nice much difference. You do also lose a little bit of the "smoothness" associated with the B48, but the torque is well worth it in Race Mode. I did have some issues after install. It ran great for about 20 minutes then i had a lot of "jerkiness" when accelerating so I disconnected it. I called DINAN and they said to clean up the connectors and reconnect it. This is the cause of 99% of the issues they said. They were right. I reconnected the module and it is good to go. My two cents are that this is definitely worth the money, especially if you have access to 93 Octane gas so you can use the Race Mode. |
