02-13-2017, 11:48 AM | #45 |
Rep 1,447
I knew it was only a matter of time...
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
02-13-2017, 11:51 AM | #47 |
Rep 7,000
02-13-2017, 12:29 PM | #48 |
Rep 1,447
I went from D7 to E6 and while I felt on E it revved cleanly, you had to rev it out to get the most from it. Switching back to C9 I felt it had more low down torque, so a bit more in gear surge.
I have the 30d engine, whereas Lee has his box on a 35d, so will be interested to see how you find map E on yours.
02-13-2017, 12:38 PM | #49 | |
Rep 2,152
well you know me haha you dont buy speedos to wear in the lounge so thought why not E9 it and see. i was thinking i might hit that wall and have to go back to E7 anyway but nope ran fine.
sooo comparing it to E7 its hard to say what the difference was as in all honesty i dont really drive my car in anger and on E7 i dont think i whacked my foot to the floor. tonight how ever. Sport mode and Sport Gear box doing some pulls from 30 ish. all i can say is WOW!!!! no wall at 3000 rpm like mentioned on the FAQ part of this thread. just pulled through nicely the kick in 3rd and 4th was amazing. shocked me in all honesty. ill run it on E9 for a few days make sure there is no black smoke. if all is ok ill leave it on E9
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
JLR19691882.00 |
02-13-2017, 01:06 PM | #50 | |
Rep 2,152
i wonder if C9 cross over E6 as effectively its turning the volume up?!? E5 = C7
02-13-2017, 01:25 PM | #51 |
Rep 7,000
Well switched from C8 to E8 and in Sport it scared me a bit, it wobbled in 3rd gear on the straight!
It's 5C so not great for run flat summer tyres In comfort mode power is always just a very small press away and its more than enough all of the time. However when I put it in Sport and accelerate its instant almost too much even with the slightest of throttle it just surges forward right to the gear change Sounds odd but not sure if it's too intense in Sport it's almost like lunatic mode, cruising along and then flooring it the kick down is instant and it's off again like a scalded cat. Be interested to know how much boost its running in E8 and by how much the fuel pressure has changed but Christ it's a hell of a different car. I can't imagine what a 335D must be like in E9 Not sure what to do now so will live with it for a while and see how it is |
02-13-2017, 01:25 PM | #52 | |
Rep 1,447
I wonder if I was finding the fuelling ceiling an issue with map E? I didn't feel like it hit a wall, but it just didn't have the same shove and seemed a bit asthmatic for me. Probably a bit more headroom in the 35d with the updated hardware.
02-13-2017, 01:51 PM | #53 |
Rep 1,453
Just be aware guys when I put mine at the higher settings that wall you hit is unpleasant.... :bulge
mine didn't happen at 3000 rpm tho more like 4000rpm and only when foot was flat... All this talk makes me what to go play again. |
02-13-2017, 01:55 PM | #54 | |
Rep 2,152
What setting you on?
02-13-2017, 01:55 PM | #55 |
Rep 1,447
What setting do you now use? And based on your experience, I take it there's no mistaking when you reach the limit point?
02-13-2017, 01:56 PM | #56 |
Rep 2,152
02-13-2017, 02:44 PM | #57 |
Rep 7,000
I am concerned that on settings E9 the fuel pressure is too high and could cause issues, the reason being is that the following statement is on the Bluespark FAQs
Our boxes are designed to work within factory tolerances and design specifications of your engine, our default maps do not excessively raise maximum fuel pressure, preventing wear on the vehicle’s fuel system. Does this mean if you move off C6 then you are really increasing fuel rail pressures and asking for premature wear? |
02-13-2017, 03:33 PM | #58 | |
Rep 2,029
JLR19691882.00 |
02-13-2017, 04:41 PM | #60 |
Rep 7,000
Have sent Bluespark an email for confirmation
Darth Helmut1780.00 Smee505.00 |
02-14-2017, 07:07 AM | #62 | ||
Rep 1,453
Smee505.00 |
02-14-2017, 08:44 AM | #63 |
Rep 2,152
woo what engine you got again. when did you change and thoughts?
02-15-2017, 09:27 AM | #64 |
Rep 7,000
Had a good run today in E8 and all ran perfectly, used auto and manual up to the redline and no issues
What are people seeing when they say it hits a wall? |
