11-13-2014, 05:25 AM | #68 |
Rep 915
Slightly non related question as posters on this thread seem knowledgable
I have HK audio, very happy with it on the whole but sometimes would like a bit lower freq bass available, can you simply upgrade the subs under the seat to achieve this, maintaining everything else as standard? |
11-13-2014, 07:02 AM | #69 | |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
11-17-2014, 06:59 AM | #71 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
Just finished my upgrade. Night and day difference in sound quality. Well worth the £700 and skinned knuckles!
11-17-2014, 07:03 AM | #72 |
Rep 3,556
Nice one!!! I'm going to leave mine until my man-flu has gone and I can hear properly again. So I can hear the base speakers before I upgrade.
02-28-2015, 06:47 PM | #74 |
Rep 32,881
06-23-2015, 02:50 PM | #75 |
Rep 28
Hello,
I got some questions: 1. Why did you use a 2channel quadlock instead of 4channel? 2. Do the rear speakers (which were not replaced) still work? 3. Are the rear speakers also powered by the amp? 4. Do you have any problems similar to those with the alpine retrofit that for example PDC is very quiet after the speaker modification? Regards |
06-23-2015, 05:17 PM | #76 | |
Rep 32,881
1. Because it's a 4 channel amp used to power the front door speakers & underseat woofers, so it only needs 2 inputs (FL & FR) 2. Rear speakers still run off the HU amp. 3. See above 4. The rears will be same as before, Dave never reported any problems with the front PDC either. |
06-24-2015, 03:26 AM | #77 |
Rep 28
okay thanks.
As far as I'm concerned the problem with rear speakers is connected with the fact that when installing the alpine retrofit kit you need to code the car to HIFI settings. As I understand, here you don't have to perform any coding?? Regards Another question - The underseat woofers are connected directly to the Mosconi AMP. Am I correct? The stock wires for underseat woofers remain unused. Yes? |
06-24-2015, 08:13 AM | #78 | |
Rep 32,881
2 outputs from amp go direct to woofers, other two go to the outer connectors on the woofer plug which feed the door speakers by the looks of it. |
06-24-2015, 09:36 AM | #79 |
Rep 28
Sorry, but I don't get what U mean by: "other two go to the outer connectors on the woofer plug which feed the door speakers by the looks of it"?
I would like to confirm: - I connect the quadlock to the amp - I connect underseat woofers directly to the amp - I connect the amp to power that's all? |
06-24-2015, 09:54 AM | #80 | |
Rep 32,881
So you need to use those thin wires to feed the door speakers by connecting the new amp to them. |
06-24-2015, 05:09 PM | #82 |
Rep 664
i think teaston has answered your questions pretty comprehensively.
just to add to the general PDC issues that the 'hifi' (U.S.) upgraders had. was because the rear PDC output comes from the rear speakers iirc. (not sure about front PDC i haven't got it) and the rears on a 'hifi' system were amped. since i'm only amping the front outputs and subs, not the rears, PDC volume isn't an issue. but...the door gongs are amped, and need turning down in the idrive settings.(think mine are on one 'bar'.) also if you get traffic reports on the radio, it can be very loud, and can make you jump if your not prepared. (though i think you can turn the volume of the traffic reports down too?) |
06-25-2015, 02:24 AM | #83 |
Rep 28
I do not use radio traffic reports, but I have RealTimeTrafficInformation which I think is not an issue as it only draws some colorful lines on navigation indicating the actual traffic on a specific road
So having in mind all the above, you confirm that you did not experience any inconvieniences after the speaker upgrade? Regards |
06-25-2015, 07:56 AM | #84 |
Rep 379
When I first had my retrofit the PDC front and rear was extremely loud even on lowest idrive setting. Caused by setting the amp with lower gain and higher input level. Swapping this round on the sound processor settings fixed it back (still needed lowest drive setting due to the higher power of the Hertz Amp)
My rear speakers are not amplified so PDC can't be coming via them alone. |
06-25-2015, 03:13 PM | #85 | |
Rep 664
the speakers do need bedding in for a while when first fitted. especially the subs as they tend to distort at high output a bit, until nicely loosened up. utterly amazing after that it's not just the volume or the extra bass, the difference in the clarity is night and day. also i followed the setup guide for setting the amps gain settings, pretty straight forward really, as they have 'pink noise' wav files to set the maximum gain for the amp. and leds illuminate when the max has been reached you then just dial it back a little. then i used the downloaded .gas file from monster audio to set the amp up. |
07-13-2015, 03:36 AM | #86 |
Rep 28
Well, I have installed the speaker set, but what I have done was just changing the midrange in doors, and adding the tweeters. I did not install the underseat subs and I did not install the mosconi amp.
Why I did so? Because the quality improved substantially, and the overall "loudness" also increased. There was no reason for me to pay additional money for mosconi amp and other accesoriess to install new subs. On the other hand, it is good to know that Professional Navigation is capable to work with new gladen midrange speakers and tweeters without amplifier. All in all, I have two gladen plug and play underseat subs for sale, also monster cables and gladen power cables (for amp). If anyone interested please PM me. |
07-13-2015, 04:28 AM | #87 | |
Rep 109
07-13-2015, 06:50 AM | #88 |
Rep 28
GLADEN ONE 200 BMW which is a predecessor of GLADEN ONE 201 BMW
http://www.gladen.com/previous_models.html#ONE201BMW Last edited by popi2009; 07-13-2015 at 07:18 AM.. |
