Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      04-21-2013, 03:22 PM   #243
Carl L
Carl L's Avatar
196
Drives: '15 M3
Thumbs up
Originally Posted by Levi View Post
No freaking way will the M3 make only 415 PS. The Maserati V6 is a 3l and makes 410 PS @ 5.500 RPM and 550 Nm @ 1.750-5.000 RPM. with 7.250 RPM redline. If the BMW will rev higher and have more torque it will at least make 440 PS.
I totally agree. For months I've said between 440 and 460 ps. Lowest I could possibly imagine is 430ps which is 424bhp, but common logic indicates more.
As for Comp packages now offering more power, it's a pretty tacky thing for BMW to do unless owners of the the non-comp models can retrofit the power bump for a small fee.
      04-22-2013, 05:15 AM   #244
BMW269
There is no Competition Package coming. You'll have to wait till facelift for that. It is not like AMG. And Competition Package isn't worth the moeny. You can get better thanks to aftermarket.
      04-22-2013, 06:11 AM   #245
malter2.0
Drives: em-funf
History repeats itself
e39 vs e46 400/333 (83% of M5 output)
e60 vs e92 500/414 (83% of M5 output)
f10 vs f80 560/465 (83% of M5 output)
      04-22-2013, 06:58 AM   #246
Uli_HH
Uli_HH's Avatar
Drives: AW M3 E90)/ 523i Touring
NO ... sad to they, but you are wrong!
Motor data sheets that are probably already been sent to some premium customers in Germany, unfortunately, confirm exactly the power that has already been made known here by the VIN -> 310 KW = 415hp = 421PS
The new F80M3 generates its superior performance one and only from the low weight and significant improvements in the chassis!
      04-22-2013, 07:26 AM   #247
mkoesel
Moderator
Drives: No BMW for now
You contradicted yourself there. I think it's almost certain a competition package will be added at some point if not right away. You think M6 won't get it until its LCI too? I doubt that. BMW will release it when it is prudent, which could be at any time for the M6, and for the M3 and M4 as well.
It depends entirely on your goals.
But, I do think that putting CCB in the package would kill it for many. I don't think they'll do that for the US cars. Could remain optional everywhere in fact.
      04-22-2013, 07:30 AM   #248
mkoesel
Moderator
We've already discussed that same effect but with respect to power-to-weight which is the more telling number. The F8x is going on a diet, and hence need not have as big a power increase to see an increase in performance. It does not mean it won't get a power increase, just that its premature to assume things - we know almost nothing about the chassis still. Hopefully that changes after M-Fest next month.
      04-22-2013, 11:08 AM   #249
malter2.0
Drives: em-funf
Ehh... F30 was suppose to be 150lb lighter than E90 and that never happened. Chassis got better, but weight loss was insignficant.
      04-22-2013, 11:23 AM   #250
mkoesel
Moderator
For the sake of argument I won't disagree. But remember, we don't know anything specific about the F8x chassis yet. What we do know is that it is not just another name for the F3x chassis. E46 M3 weight is rumored to be the target for the car.
At this point, I figure a 3700lb+ F80 M3 with a 465hp engine is all but totally out of the question. We should know soon.
      04-22-2013, 02:38 PM   #251
malter2.0
Drives: em-funf
I hope so...
Personally, I would much rather have 3400-3500lb with 414hp than 3700lb with 465hp.
      04-22-2013, 03:07 PM   #252
NISFAN
NISFAN's Avatar
Drives: BMW M2
But it is lighter.........and F3x went back to steel suspension parts, has more equipment and bigger wheels than e9x
Yet is stiffer and a bigger car.....well done BMW
      04-22-2013, 03:39 PM   #253
Carl L
Carl L's Avatar
196
Drives: '15 M3
You state this as if it's fact, while in reality it's just your opinion.
      04-22-2013, 04:29 PM   #254
BMW269
I hope so...
And what about 3400-3500lb with 465hp?
      04-23-2013, 02:10 AM   #255
Uli_HH
Uli_HH's Avatar
What about 1.480kg = 3.265lbs and 310KW = 415hp = 421PS for an standard trim F80 without extras (but also without CCBs!) ... and later (LCI?) with the Competition-Package ~320KW !!!???
I donīt state this as if itīs fact ... but its also not simply my opinion! These numbers are rumored by the leaked VIN and should be quoted in detail in Motor data sheets, that some premium buyers had seen.
And also an NOS time of 30sec faster than the previous M3 should be confirmed by an famous race driver !
      07-30-2013, 04:33 PM   #256
Voltigeur
MacroRisk
Voltigeur's Avatar
Australia
109
Drives: M3 E92 ED'09 / 335d Sport DD
Originally Posted by tuna_hp View Post
Another weird issue is that the new modular I3/4/6 engine platform that BMW has started building (including the N20 and all the 1.5L I3 engines that have been in the news) is designed for up to 75hp/cylinder. They have already proven that out with the 220hp 3 cylinder that is going i8 car. This would mean that using standard components from this new modular platform, BMW should easily be able to build a ~450hp 3.0L I6 engine. Why heavily modify the outgoing version when a newer, more efficient, more powerful, and presumably cheaper alternative is readily apparent?
Agreed: doesn't make any sense unless a later Comp Pkg is tuned to higher hp.
Just thinking of something not so witty
///M3 E92 '09 Jerez Black | 6MT | Ext Fox Red | Tech | Prem | 19s |Heated Seats | iPod |Smartphone | Euro Deliv June 09
Sold: 540iT / 530i / 323i
2013 bmw m3, 2013 bmw m4, 2013 m3, 2013 m4, 2014 bmw m3, 2014 m3, 2014 m3 forum, bmw f80, bmw f80 forum, bmw f80 forums, bmw f80 m3, bmw f80 m3 s55, bmw f80 m3 sedan, bmw f82, bmw f82 forum, bmw f82 forums, bmw f82 m3, bmw f82 m3 coupe, bmw f82 m3 forum, bmw f82 m4, bmw f82 m4 coupe, bmw f82 m4 s55, bmw f83, bmw f83 m3, bmw f83 m4, bmw m forum, bmw m forums, bmw m4, bmw m4 coupe, bmw m4 coupe forum, bmw m4 forum, bmw m4 forums, bmw s55, bmw s55 engine, bmw s55 motor, f80, f80 forum, f80 forums, f80 m3, f80 m3 forum, f80 m3 forums, f80 m3 s55, f80 m3 sedan, f82, f82 coupe, f82 forum, f82 forums, f82 m3, f82 m3 coupe, f82 m3 forum, f82 m4 coupe, f82 m4 forum, f82 m4 forums, f82 m4 s55, f83 m3, f83 m4, m forum, m forums, m3 f80, m3 f80 forum
f80post
