05-25-2015, 12:48 AM | #1 |
Rep 126
335xi with mppk sluggish at 50k miles
Over the past 6 months I've noticed the turbo lag has increased and general smoothness of throttle is gone. The engine seems very underpowered like im not even stepping on the gas and then the turbo kicks in hard 2 to 5 seconds later and the car almost seems to overboost. I have a 335xi w mppk and the sport+ transmission options. This problem happens in any driving mode but I'm most concerned that it's happening in sport and sport plus modes. Those modes should have power readily available and very little lag or at least they always used to for me. Also the car is warmed up and I'm using the highest octane fuel. My car is rounding the 48k mileage mark and has a clean bill of health as far as I know.
I've tried flipping it to Manuel to keep the revs right at 3k before stepping on the gas and that still does not help alleviate the lag. Do these cars just stop performing well at 50k mileage? Any ideas on how to fix this. I've read it could be carbon buildup on injectors but is there anything else? |
05-25-2015, 01:18 AM | #2 |
SPEED RACER
375
Rep 740
Try reseting your foot pedal by putting the car into accessory mode or just turn on the car by pressing the start button WITHOUT the brake pedal. Then go ahead and depress the accelerator all the way to the floor past the click point. Hold the pedal down for 30 seconds then proceed to switch the car off. Now restart the car and it should help.
You could also try the italian tune whereby you put the car in the manual shifting and while driving, keep the revs around 4-5000 rpm and get the engine temperature up to about 250 F + but below the 300 F mark. Drive for about 15 mins.
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black |
05-25-2015, 01:30 AM | #3 |
Rep 23
Did you get the valves walnut blasted? You could have excessive carbon build up that is causing the car to act sluggish. Who does your service?
05-25-2015, 02:21 AM | #4 |
Rep 126
I have a stealership apt this week hopeful that the walnut thing will be covered under warranty.
I have reset the throttle doing that on off pedal down thing in the past but it doesn't seem to zero out the lag. I remember the first 30k miles i had the car the acceleration was fierce and linear and i never felt under powered; Compared to now where accel is really almost unpredictable. |
05-25-2015, 07:50 AM | #6 |
Rep 3,064
Disconnect the battery for >1h.
replace the following if you haven't done already: spark plugs, and air filter. Never hurts to do an oil change after spark plug replacement as well. If that doesn't work then probably carbon build-up which requires cleaning. |
05-25-2015, 09:28 AM | #7 |
Rep 592
Possibly carbon buildup
Need walnut shell blasting Or at least their foam cleaner
2011 335i Space Grey Msport E90
BMW Performance Exhaust PPK Stage I Lux H8 , HID Fog lights 5k |
05-25-2015, 10:41 AM | #8 |
Rep 3,469
05-25-2015, 10:44 AM | #9 |
Rep 5,316
Drives: G80 M3 6MT
Pretty sure 50k becomes the interval plugs with MPPK.
Spark plugs and walnut blasting. It will feel like day 1.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
05-25-2015, 01:04 PM | #10 |
SPEED RACER
375
Rep 740
Try the Italian tune up
05-25-2015, 04:43 PM | #12 |
SPEED RACER
375
Rep 740
Well you have to keep the revs up at the 4-5000 rpm range and keep it there for a couple miles and get the engine temp higher than it normally is. Helped fix my sluggish n20.
05-25-2015, 08:16 PM | #13 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
Spark plugs need to be changed at 40K for MPPK. Give that a shot
05-25-2015, 09:07 PM | #14 |
Rep 1,627
Is this covered under the maintenance program
M4 in MG | 6 MT
05-26-2015, 01:33 AM | #15 |
Rep 418
Every throttle/ turbo lag issue I have experienced with BMW cars has been as a result of the air mass meter failing, despite no engine light.
You might try cleaning it very very carefully with an appropriate type of cleaner found your side of the pond. If that doesn't fix it, I would replace it anyway. It's as important as the throttle cables, which we no longer have, as it's the primary communication tool between your foot and the engine. |
05-26-2015, 08:25 PM | #16 |
Rep 3,341
05-26-2015, 09:03 PM | #17 |
Rep 1,627
I just asked my SA when my 2014 MPPK 435i needed its spark plugs changed and he said it was 65K miles.. I had planned on changing at 50K and just pay for it...
M4 in MG | 6 MT
05-27-2015, 12:52 PM | #18 |
Rep 3,341
With my e90 they said it was part of the year 3, or 45,000 mile service, and wouldn't pull it ahead. Didn't realize they changed it for F30.
07-08-2015, 12:29 PM | #19 |
Rep 126
just got it back from the shop. New plugs and the rear suspension was leaking and broken. The new suspension alone seems to have corrected it. maybe my car was just squatting due to the break.
335xi, 50k, lag, mppk, sluggish |
