10-03-2013, 09:46 AM | #1 |
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
Brake Fluid?
To those of you that have flushed out the BMW brake fluid and replaced with something with a higher boiling point - what did you use?
10-03-2013, 04:08 PM | #4 |
Rep 210
From least to most expensive, ATE, Motul 600, and Castrol SRF.
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09 Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11 Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19 |
06-26-2014, 12:33 PM | #6 |
Rep 573
No, 2 are required if you're changing from stock to something else. Otherwise you'll just have new in the reservoir and old in the lines and calipers - right where you don't want it.
After that, just run 1 bottle through the system every 6 months or after every big track weekend. BTW I went with RBF600 - works like a champ |
07-14-2014, 12:50 PM | #8 | |
Rep 573
http://f30.bimmerpost.com/forums/sho...&postcount=149 The Motive power bleeder is awesome for 1 man bleeding |
12-15-2014, 01:40 PM | #9 |
82
Rep 256
03-27-2015, 07:34 PM | #10 | |
Rep 927
ATE is sold in 1L bottles.
Craig Brickner
Click to Join: BMWCCA # 366493 |
05-01-2015, 11:05 PM | #11 | |
Rep 34
+1 also on the RBF 600. Have also used Motul 5.1 for DD with the occasional HPDE. |
07-20-2015, 07:02 PM | #12 |
2006 TIME Person Of The Year
9720
Rep 6,445
I found one bottle of RBF was more than enough to completely flush the system in my F30 w/ M Sport brakes. I actually have 10% or so remaining.
In the end I did actually use two bottles. I only achieved perfect hydraulics after flushing twice with activating the ABS/traction control a few times between bleeding sessions. I drove a week or so between bleeding sessions making sure I get the valve block in the brake system flushed out. Along with SS lines, the M Sport brakes feel awesome with a proper bleed.
09-30-2015, 09:18 AM | #15 |
Infidel
122
Rep 1,102
How bad does the OEM fluid get with normal/inspired everyday driving? Just had my first fluid service last week after 3 years..........
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
09-30-2015, 05:10 PM | #16 | |
Rep 573
OEM fluid is less hydrophilic than racing brake fluid - the trade off is racing brake fluid has a higher dry boiling point Meaning racing brake fluid is much better when new, resists boiling at much higher temperatures, but absorbs water faster making it last less time. BMW recommends changing the OEM fluid every 2 years for safety reasons. If you're going with a racing brake fluid, figure every 6 months. |
Gertsee51.00 |
10-01-2015, 02:58 AM | #17 | |
Infidel
122
Rep 1,102
So, why did my car not want it til now? Is the 2-year interval something new or depending on market region maybe?
10-03-2015, 04:17 AM | #18 | |
Rep 603
BMW uses glycol based brake fluides DOT4. Don't use DOT5 or you will kill your brake system! https://en.wikipedia.org/wiki/Brake_fluid As written the fluid will lower the wet boiling point over the time. You can test the brake fluid boiling point with special equipment. In any driving/braking conditions you want you brake fluid NOT to reach the boiling point. This will cause gas bulbs in the system and immediate brake power loss. When the fluide cools down, brake will work fine again. On regular street use a boiling point of 180°Celsius could still be fine, but on heavy track use it could be that this is already to low. The bad thing is: If you find out, it could be too late The change interval is good for normal use, but if you track your car, you may want to control the boiling point from time to time. It is also important to have the brake fluid reservoir closed and sealed. Avoid that water drops get into the system (i.e. from cleaning the engine with high water pressure) Besides Boiling point corrosion and viscosity are other factors, why brake fluids need to be changed. (as wiki explains)
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
03-04-2016, 01:44 PM | #19 |
Rep 46
RBF FTW
03-17-2016, 09:45 PM | #20 |
9720
Rep 6,445
I push a new bottle of Motul through my car every time I switch summer/winter tires; and before and after any time the car goes on track. Sometimes I'll rotate MTL Blue just so the color change (Motul is clear) proves I pushed the old juice out.
03-22-2016, 10:55 AM | #21 |
Rep 766
Lots of people I know love the Castrol SRF because they change it less, I've been very happy with 600 RBF.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
07-14-2016, 12:57 PM | #22 |
NoCo's Marketing Pawn
Rep 81
Anyone recommend a good oil for hot Arizona summers? It gets upwards of 120 here and we have to change oil more frequently because of it.
