BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Possible HPFP cooked ??
Studio RSR
      04-04-2024, 12:37 PM   #1
Skrrtt335
Drives: 2015 335
Today i was driving my car and it shut off while idling at a red light . car wont start only cranks. Had about 50 miles left in gas tank . i am guilty of driving the car low on gas plenty of times and ran out of gas about 3 times total . LPFP is showin 84 psi in log & HPFP IS SHOWING 80-85 Psi when cranking . checked the codes through bm3 and got these codes. im assuming its the hpfp but i want to see if anybody else has had this issue and if they solved it or if anybody has thoughts of what it can be . thanks
car also had stalling issue when i drove for long periods of time ( 1-2+ hours ) it would start back up ( only happened about 3-4 times since 2 years ago ) hasnt happened for about 6 months
BMW specialized shop is charging $520 for labor to replace hpfp . how hard is this to do myself and what tools would i need ? & is there a way to do it without removing manifold
21a023- combustion engine false start
11b401- high fuel pressure during or after he injection is enabled ( 2nd set of environmental conditions after a time delay - pressure too low
11a401- high fuel pressure when injected is enabled : pressure too low
      04-04-2024, 12:57 PM   #2
AmuroRay
AmuroRay's Avatar
2317
Drives: M235i
You can have my old one for free if you need it.
Mods: Yes.
      04-04-2024, 01:08 PM   #3
Skrrtt335
Drives: 2015 335
damnnnn g you about to bless me like that ? its my birthday today too i would appreciate that
      04-04-2024, 01:08 PM   #4
thejeremyman9
thejeremyman9's Avatar
4374
Drives: 2015 BMW 335i
How are you reading LPFP pressure?
      04-04-2024, 01:14 PM   #5
Skrrtt335
Drives: 2015 335
did a log with bm3 while cranking car and LPFP act raw is showing 84 psi
HPFP act raw is 80-85 while while cranking and without cranking ( car in on position ) with hpfp target at 1750 only while cranking
      04-04-2024, 01:47 PM   #6
thejeremyman9
4374
There is no LPFP pressure sensor, that's not real data.
But your HPFP pressure may suggest that your LPFP is working. can you hear it?
johnung4540.00
      04-04-2024, 02:09 PM   #7
Skrrtt335
Drives: 2015 335
gotcha thanks for clearing that up , i didnt check for sound of the lpfp so ill do that .
      04-05-2024, 03:18 PM   #8
Skrrtt335
Drives: 2015 335
lpfp is turning on going to replace hpfp will update
      04-10-2024, 05:24 PM   #9
Skrrtt335
Drives: 2015 335
Replaced HPFP with the one you sent over and car is back on thanks bro
AmuroRay2316.50
      04-10-2024, 05:39 PM   #10
AmuroRay
AmuroRay's Avatar
2317
Drives: M235i
You're welcome!
Mods: Yes.
      04-10-2024, 06:01 PM   #11
thejeremyman9
4374
I'm curious if the HPFP looked physically damaged? Failure is pretty rare since its mechanical
      04-11-2024, 01:18 PM   #12
Skrrtt335
Drives: 2015 335
Looked normal to me i compared them side to side and were the same . The bad hpfp just had alot of debris & was dirty . i did run out of gas about 4 times idk if that has anything to do with it
      04-11-2024, 01:27 PM   #13
thejeremyman9
4374
That might be a good takeaway - running out of gas can do that.
