03-21-2013, 07:19 PM | #2993 |
Rep 10
Folks,
I am new to BMW coding (but not to the world of coding/programming in general). I am looking to code a few options on my 2012 F30 328i Sports line with Premium, Tech, Xenon lights with BMW Assist and Advanced Bluetooth, etc. I would really appreciate your help with a few questions I have: 1] Cable - are the places listed in the OP still the best sources for buying the cable? 2] Software - I use a Mac, so I am looking for a place where I can download the software and the relevant data files. Couple of things that I am hoping to code eventually: get ipod out using the USB cable, video in motion, possibly enabling BMW live (do I need the BMW Convenience plan to enable Live?) Thanks in advance |
03-21-2013, 07:38 PM | #2994 | |
Rep 1,892
Software is PC only, so you will need to run it under Parallels or something similar. Checkout the more technical bimmerpost coding forums for details and pitfalls. I don't think you'll get iPod out without the cradle and I think enabling BMW live will disable BMW Assist. I'm sure others will correct me if I'm wrong. At least DVD in motion is easy to do! |
03-21-2013, 07:41 PM | #2995 | |
Rep 1,130
Drives: '16 340i AW MSport
03-21-2013, 07:58 PM | #2996 | |
Rep 1,892
try this: http://www.amazon.com/Cable-J1962M-O...eywords=J1962M or this: http://www.amazon.com/Cable-J1962M-O...eywords=J1962M I got the 10 footer and made my own cable with 1/2 of a grounded Cat-5 patch cable, a 510 ohm resistor and some soldering and shrink tubing. |
03-21-2013, 09:40 PM | #2997 | |
Rep 40,951
http://enetcables.com/
03-21-2013, 09:41 PM | #2998 | |
Rep 40,951
03-21-2013, 09:51 PM | #2999 |
Rep 490
Is there any way to VO code without actually writing the FA to the vehicle?
I tried this morning removing certain VO from the vehicle, intentionally skipped the step to write FA to vehicle, proceeded to code Combox & CIC which worked ok, but the specific option code that i remove also got deleted from the FA |
03-21-2013, 09:54 PM | #3000 | |
Rep 40,951
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 03-23-2013 at 08:10 AM.. |
03-21-2013, 10:09 PM | #3001 |
Rep 40,951
I would reset the ECU (VO Code) and try it again from scratch. It should work just with those 3 codes, and by changing only the drop-downs.
03-21-2013, 10:12 PM | #3002 | |
Rep 40,951
03-22-2013, 01:07 AM | #3003 | |
Rep 490
Should I therefore => Read FA > edit & save FA > "how to exit FA?" > load FA > activate FA > code ECU. |
03-22-2013, 04:14 AM | #3004 |
Rep 407
I tried changing 6NH to 6NK today and got this error when I coded HU_ENTRY
Transaktions-Report: Aktion: Codieren HU_ENTRY [63] cdDeploy ProcessedWithError cafd_000000f9-007_003_024 ProcessedWithError The head unit would not go past the BMW splash screen. I changed the VO back to 6NH, recoded and it was working again. What am I doing wrong?
03-22-2013, 08:15 AM | #3005 |
Rep 40,951
By Exit, I meant only to save the FA, then click on the Coding module. From there, make sure the modified FA is loaded and active, then VO Code the ECU.
03-22-2013, 08:19 AM | #3006 | |
Rep 40,951
Beyond that, I am not sure a Basic Head Unit can support 6NK. I think you need HU_CIC and CMB_MEDIA (Combox) to switch from 6NH to 6NK.
03-22-2013, 08:30 AM | #3007 | |
Rep 490
I move from FA editor to Coding, and esys prompted to reload the FA, which I click yes, and I saw the file pre-loaded in the Coding screen, and seeing that the option i want to get rid off is no longer there, so i proceeded to code, which went well. Just don't understand why the vehicle FA was updated as well since I didn't write the modified FA back to the car |
03-22-2013, 10:05 AM | #3008 | |
Rep 407
Yes I have coded everything without getting an error. I guess the only reason is HU_ENTRY not supporting 6NK
03-22-2013, 11:12 AM | #3009 |
Rep 343
Please keep us updated... thanks bud
2012 F30 328i, Alpine White on Black, Luxury, Premium + Exec. Package...
03-22-2013, 12:05 PM | #3010 |
Rep 1,894
Hi, I'm just getting the software all setup up, I've just confused on the psdzdata files:
The psdzdata.7z.001, psdzdata.7z.002..... do I need to combine these 7z files or form a massive file or do I leave them in their current form? Or unpack them separately before moving them in the C:\ESysData\psdzdata\ Thanks. |
03-22-2013, 12:18 PM | #3011 | |
Rep 1,027
M Sport Line Estoril Blue
03-22-2013, 01:33 PM | #3012 |
Rep 1,894
All I got were lots of psdzdata.7z.001.....etc files. Should I just copy these over?
Also the next part says "Copy the contents of the "C:\ESysData\psdzdata\swe" folder into the "C:\ESysData\SWE" folder." I don't seem to have this folder C:\ESysData\psdzdata\swe. |
03-22-2013, 01:37 PM | #3013 | |
Rep 40,951
You can ignore that second step. Nothing is needed in the C:\ESysData\SWE folder, and doing so will only waste 20 gb of HD space.
03-22-2013, 03:20 PM | #3014 |
Rep 1,894
Thanks a million. Unzipped and ready to go
