10-09-2013, 10:01 AM | #111 | |
Rep 3,780
300hp is a very modest power level(for a 3500lb RWD car). So is 400. On cars equipped with 255mm rear tires, in dry weather, you should have traction briefly interrupted in the 1-2 shift, and MAYBE the 2-3 shift with the 8spd. When you start breaking traction at over 40-50mph in higher gears you are likely seeing DOUBLE the power of a stock N55.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
10-09-2013, 10:08 AM | #112 | ||
Rep 3,619
I stand corrected then
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
10-09-2013, 10:13 AM | #113 | |
Rep 3,780
Stock, N20, 255mm rear S001's, I could spin on the 1-2 shift, and chirp on the 2-3 shift. So imagine what the added power of the N55 would do.
10-09-2013, 10:24 AM | #115 | ||
Rep 3,619
10-09-2013, 10:35 AM | #116 | |
Rep 3,780
I will say- this week someone from a turning lane went to go straight and bully me from a greenlight as I was going straight. This led to a noiseless smoking burnout in first at a 20mph roll, then into second where I tipped into it a bit more and again smoked the person out as I fishtailed a bit and took off. Twas fun :P
10-09-2013, 10:46 AM | #117 | |
Rep 9,709
Lets look at this.... The information you rely on states that a 335iX gets to 60mph 0.2 seconds faster than a 335iS. Sounds about right to me given AWD traction in the first 15-20mph range. ....but then the heavier, more power loss through the drive train 335iX maintains it's 0.2 second lead all the way through the 1/4. A 335i typically traps at around 103-105mph. So the suggestion is that the heavier 335iX has no disadvantage from 60-105mph. Clearly the RWD is not powerful enough to spin the wheels at 60+mph so what the heck is happening here? Then miraculously, the 335iS goes from say 104mph (typical 1/4mile trap speed) to 120mph in a whole 0.6 seconds faster than the xdrive, even though it couldn't gain any time the 20mph before this. (0.2 seconds behind at the 1/4 then 0.4 seconds ahead at 120mph). What was it wheel spinning at 80mph? It doesn't take a genius to realise that other factors are at play here, and therefore the figures are NOT comparable. |
10-09-2013, 10:52 AM | #118 | |
Rep 9,709
On a fast MT gear change, it is drivetrain inertia chirping the wheels, not engine power. i.e a heavy flywheel, and I'm sure you'll find a 328 has a similar weighted flywheel to a 335i |
10-09-2013, 11:00 AM | #119 | |
Rep 3,780
Same thing with drifting, it looks cool, but it is not the fastest way around the track
10-09-2013, 11:19 AM | #120 | |
Rep 1,285
I note however that for the F30 the AWD does not have an advantage on corner exist as it possesses insufficient power to brake the rear tires loose other than in a very slow corner, or if driven in a deliberately ham-fisted fashion. |
10-09-2013, 11:21 AM | #121 |
Rep 688
10-09-2013, 11:28 AM | #122 |
Rep 1,285
That is, you now recognize xDrive inherently understeers more than RWD?
If not, perhaps you will now address the points I raised such as the xDrive using more of its available cornering traction than RWD on the same corner, and xDrive ability only to reduce the understeer the xDrive system itself directly causes, etc. |
10-09-2013, 11:42 AM | #123 | |
Rep 9,709
This technique involves getting the rear end of the car out during the braking phase to a position that points the nose of the car at the apex. Power is then applied to drive the car towards the apex. All 4 wheels are pointing straight ahead in this position. Very similar (not as aggressive yaw angles) to Rally and Ice racing. This is used by professionals only in an attempt to neutralise AWD under-steer. |
10-09-2013, 11:51 AM | #124 | |
Rep 3,619
On the other hand I suggested that the advantage of the rwd from a rolling start at 45mph is overblown and gave some examples.
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages Last edited by 300hp; 10-09-2013 at 11:57 AM.. |
10-09-2013, 11:55 AM | #125 | |
Rep 3,619
10-09-2013, 02:54 PM | #126 |
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
I live in the so called snow belt- I have never been stuck. If I went to ski country a bunch, I might concider an xi but probably not. It's not worth giving up fuel economy and handling for the 30 or 40 days a year we actually get snow. The car is awesome with a set of blizzaks.
10-09-2013, 04:41 PM | #127 |
Rep 1,715
Can you do 80mph in a downpour with RWD? Thought not. Cruise muddy(steep) terrain? Nope.. All better reasons to get X drive than strictly for snow. Even then, you may be okay in most conditions, but snow tires wont help going up an icey hill.
10-09-2013, 04:52 PM | #128 | |
Rep 9,709
10-09-2013, 04:55 PM | #129 |
Rep 9,709
Why would going 80mph in a downpour be difficult in a RWD?
10-09-2013, 04:59 PM | #130 | ||
Rep 3,619
10-09-2013, 05:52 PM | #131 |
Rep 3,780
Yes, 80 in a downpour. Muddy steep terrain? Where the hell are you driving lol. If it's that muddy and steep you should not be driving an Xdrive car either lol.
10-09-2013, 06:05 PM | #132 |
Gateropode
329
Rep 2,848
And you should not, even with AWD. False sense of security leads to catastrophic outcome.
The problem with downpour is visibility and lack of braking traction (and possible hydroplaning), all of which has nothing to do with AWD or not. |
