BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > This is what a doomed N55 Sounds Like
proTUNING Freaks
      10-17-2013, 02:55 PM   #1
gomichaelkgo
Drives: 2014 335i
I've had this weird noise in my F30 since the day I bought it new. Turns out it was a bad connecting rod bearing. After multiple visits to the dealer with a "could not duplicate" diagnosis, they finally troubleshot it in earnest and found excessive wear in one of the cylinders. I'm not happy about the situation. I was rather hoping it would have been a broken bell housing bolt or an exhaust component.
Edit/Update: it wasn't the engine. After the complete engine replacement, I hear this under moderate engine load at cold start, but only intermittently. It sounds like a goat in the engine bay.
      10-17-2013, 02:59 PM   #2
335BOY
Drives: 2017 SQ5
....not a lot of bearings on pistons............
      10-17-2013, 03:00 PM   #3
gomichaelkgo
Drives: 2014 335i
ok fine, connecting rod bearing.
      10-17-2013, 03:02 PM   #4
335BOY
Drives: 2017 SQ5
can barely hear it on vid. Must sound brutal live. That would be th episton slapping the cylinder i guess. They will probably give you new short block if walls are scored badly .
      10-17-2013, 03:05 PM   #5
E92Jay
E92Jay's Avatar
17
Drives: 2014 335i
Eww, throwing a rod bearing so soon? Any ideas why?
2005 E46 M3 (Sold)
2010 E92 M3 (Sold)
2014 F30 335i M-Sport (M3 Placekeeper)
2015 F80 M3 SSII/Black
      10-17-2013, 03:05 PM   #6
gomichaelkgo
Drives: 2014 335i
You can hear it best at 0:05. Sorry for the poor audio -- it was an intermittent sound and definitely audible. I had to resort to whipping out the phone to catch it. They're replacing the entire engine assembly.
      10-17-2013, 03:07 PM   #7
gomichaelkgo
Drives: 2014 335i
It came bad from the factory. I heard it the second time I turned the car on. In retrospect, I should have hounded the dealer about it harder from the start. I kept hoping it would go away after the break-in period.
      10-17-2013, 09:39 PM   #8
Elk
Drives: 2012 335i
Likely a mistake in assembling the engine, such as reversing the bearing thereby leading to lubrication failure.
OP, sorry to learn of your issue. Very frustrating.
      10-17-2013, 10:43 PM   #9
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
Holy sh1t. This is exactly the sound I have been complaining about right from the beginning. It is like a "click click" sound coming from the engine when you try to accelerate modestly (without making engine speed too high) at slow speed.
It is almost impossible to replicate this issue since it happens mostly on a cold engine for me.
What is the fix for this issue? New engine???
      10-17-2013, 11:16 PM   #10
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
Damn. That's the exact wierd noise my car has been making since new. Figured it was just some sort of engine heat shield vibrating. Gotta be kiddin me. It feels fine though. Just another thing I need to try and have them fix.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      10-17-2013, 11:51 PM   #11
bavarianride
Drives: bimmer
wow 0:05 does not sound good! How did the dealer diagnose that one cylinder has excessive wear? Maybe a compression test? Mine is N26, it has some wierd sound during acceleration, but it is more like a whirlwind noise than a knocking one like your video. The tech said it is normal turbo spinning sound.
      10-18-2013, 12:42 AM   #12
Mobster1983
Drives: 2014 BMW 335i
How long have you had the car and how many miles does it have on it? I would definitely try to do a vehicle buy-back and get a new BMW. Having the engine replaced so early is not good and will likely kill the resale value (unless it's a lease).
      10-18-2013, 01:42 AM   #13
henryeeex
Drives: 2013 335i
I also have the same noise randomly when the AC is off. With the AC on, this sound goes away for good. I tried to diagnose this sound with my dealer a few times. He adjusted the heat shield once (which did help a lot actually). The noise is still there randomly with the AC off. My dealer foramen then got a loaner f30 335i and we tested that out and the noise was intermittently there too. Your video also sounds like this video
Seems like a fair amount of forum members with F30 335i experienced this noise too in their own car; how likely that all our engines have a bad connecting rod bearing? T_T
      10-18-2013, 02:08 AM   #14
rallybull
rallybull's Avatar
I'm taking my car back to the shop. How many of you facing this sound have experienced this clicking engine sound only during the first 5 minutes from a cold start?
      10-18-2013, 02:17 AM   #15
Steve33
Steve33's Avatar
Drives: 2018 SQ5
I experience a clicking noise all the time, but not sure where it comes from. Before work in the AM I'll pop the hood and check the origin.
      10-18-2013, 08:52 AM   #16
335BOY
Drives: 2017 SQ5
Valve train. As oil warms it climbs to top and stops ticking.
      10-18-2013, 09:02 AM   #17
Elk
Drives: 2012 335i
Direct injection also ticks as a result of turning on and off the fuel. The fuel is highly pressurized with DI. The 328 is much worse than the 335 in this regard. This is less an issue when the engine is warm.
Very few will have a failing bearing and are probably hearing other, perfectly normal, noises.
      10-18-2013, 09:34 AM   #18
335BOY
Drives: 2017 SQ5
true, good point.
      10-18-2013, 11:39 AM   #19
kppanic
Drives: 2015 Macan S
ahhh the clicking noise! my car permanently had it and happens when the gas pedal is pressed. annoyinggggggggggg but I can seem to find where it is coming from. Happens on cold ambient temperature. let me know if you find a fix for this..
2015 Macan S Sapphire Blue 20" SD Wheels Painted Black SD Kit Sport Black Chrome Exhaust
2012 BMW 328i Sapphire Black Blk Interior Premium Executive
      10-18-2013, 11:41 AM   #20
kppanic
mine never stops ticking or clicking.
even when the engine is fully warmed and been driven for hours. Only when the gas pedal is pressed...
      10-18-2013, 05:32 PM   #21
gomichaelkgo
Drives: 2014 335i
Yes, the solution was a new engine. At least I hope that was it. The dealer still has the car. You should try and get a video of your car doing it. That will help the shop people a lot in narrowing down what kind of intermittent noise they're looking for.
      10-18-2013, 05:33 PM   #22
gomichaelkgo
Drives: 2014 335i
I believie they took the oil pan off or took the top of the engine off. I haven't seen it in person, so I don't have a lot of detail. Sorry!
