10-02-2015, 02:26 AM | #1 |
Rep 101
Quiet Intake recommendation? and compatibility with BMS OCC
Hi All,
I am thinking of upgrading my F30 N20 Intake system and personally i would like to have a quiet intake and also a dry filter type. I HEARD that the oil type has slightly higher chance to kill the MAF sensor in the car. Obviously i don't have any experience on that saying, but it does make sense to me. Specially when it is cleaned by the user and applied too much oil on it. and personally i would say myself to be a professional DIYer. So i think i am better off with the dry type. So with the limitation of dry filer type, i now have injen and AFE choices. Other brands are either oil type filter or unspecified (like gruppe M). I also prefer a quiet one as i am not a zealot for BOV woosh sound. I rather enjoy the music in my car. Weight is another factor i would like to take into account, but not the leading factors. AFE states their intake are quiet and injen is proud of their woosh sound (honestly they do sound awesome, but i just don't want it all the time). So is AFE my only choice? Yes, it might be if it fits with the BMS oil can catcher (OCC). I have read posts saying they do not compatible with the BMS OCC, which i have it in my car already, and i have no intention to remove it. Does anyone has experience with AFE momentum pro or magnum force intake system with BMS OCC? Of course other brands recommendation is also welcomed. Thank you all for the help. Last edited by LittleBlackHawk; 10-05-2015 at 10:10 PM.. |
10-02-2015, 09:47 AM | #2 |
Rep 599
Why not just run an afe dry in the stock box if you want a quiet intake? Theres not really much for gains to be had. And also you're concerned about intake weight?
10-02-2015, 04:10 PM | #3 | |
Guest
Rep n/a
Drives:
Also, in reference to the comment regarding oiled filters. Assuming the filter is properly oiled, there should not be an issue with MAF contamination. We utilize oiled air filters within all of our intake kits and have never had an issue with failed sensors. Unless you are completely set on a dry unit, I would recommend at least considering the oiled units. Our oiled filters provide great filtration as well as fantastic flow. If you would like to check out our data from testing, or a video featuring our intake system, check out the thread below. http://f30.bimmerpost.com/forums/sho...ight=mishimoto Let me know if I can answer any additional questions! Thanks -John |
10-05-2015, 10:31 PM | #4 |
Rep 101
Hi Beachside and John, thanks for the recommendation. maybe a drop in is the solution for my situation.
Hi John, that is a very nice write up you posted, especially the analytical comparison between the stock and upgrade intake with tune or w/o tune with TRUE data. Thank you for sharing it. |
10-05-2015, 10:36 PM | #5 |
Rep 1,425
If you're not doing it for the sound, save yourself a lot of money and go with a drop-in filter. Or if you insist on a full intake, aFe Momentum (not Magnum). Just don't get an open intake. One with a box will conceal the sound better.
10-07-2015, 09:47 AM | #6 |
Rep 4,314
i'd get this
10-08-2015, 04:34 PM | #7 |
Rep 1,374
Drives: Audi R8 v10 Spyder
GruppeM Ram Air System make some great intakes. The quality is
10-08-2015, 09:11 PM | #8 |
Rep 110
If you want performance and no increase in noise. Drop in a K&N filter to stock box, open up another cold air feed next to factory box rectangular inlet using flex hose down to brake inlet area and also use a 90 degree "air diverter" where factory inlet is behind the kidney grill. The volume, speed and cooler air will guarantee to make the inlet side of the engine more efficient.
10-08-2015, 09:15 PM | #9 |
Rep 110
There are hardly any gains to be had with aftermarket intakes. Unless they are cheap - their value will be questionable. Save money up for catless DP if you want actual noticeable gains in power, torque, response and fuel economy
intake, occ, quiet |
